Quăng cái log repair lên coi thử đi bro.
em làm theo cách của anh phú Sài Gòn rồi mà không được ,,,, hay em làm sai trỗ nào,,,
vâng
MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C08727CF
Using device: HTI, FW ver: 00.50, SN: 01006314
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Phone type: RM-437 (Nokia E63)
SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia
ApeCoreSw: 510.21.010
Using cached productData.
PUBLIC ID: 059001099C928D52A479AC85174CCF07C7D228CE
PRIVATE ID: 1C0DB28EB737AEE477568207FC18B52CAB1BDC3F
Updating SUPERDONGLE_KEY ...OK
Authenticating to SUPERDONGLE ...
SUPERDONGLE authorized!
Writing RFBB data: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\E63_RM-437.txt ...
Writing RF settings to phone ...OK, finished. 25 Records found.
Writing BB settings to phone ...OK, finished. 9 Records found.
Done.
ở trỗ PMM Auth ak...... em ấn rồi nhưng nó không cho làm.... nó báo
access violation at address 042B0724, Read of address 00000008
mình nạp lai file 308 vào cho nó phải không anh
em thấy file 308 không vào
Done.
Phone authenticated to SUPERDONGLE already.
Writing PM from Node ...
Section: 1
- Key: 0, size 115 bytes written.
- Key: 2, size 99 bytes written.
- Key: 4, size 111 bytes written.
- Key: 6, size 99 bytes written.
- Key: 8, size 111 bytes written.
- Key: 13, size 99 bytes written.
- Key: 16, size 99 bytes written.
- Key: 18, size 99 bytes written.
- Key: 20, size 99 bytes written.
- Key: 22, size 17 bytes written.
- Key: 23, size 5 bytes written.
- Key: 24, size 85 bytes written.
- Key: 25, size 5 bytes written.
- Key: 26, size 111 bytes written.
- Key: 28, size 99 bytes written.
- Key: 29, size 11 bytes written.
- Key: 31, size 99 bytes written.
- Key: 33, size 37 bytes written.
- Key: 34, size 81 bytes written.
- Key: 35, size 17 bytes written.
- Key: 37, size 5 bytes written.
- Key: 39, size 37 bytes written.
- Key: 41, size 183 bytes written.
- Key: 44, size 183 bytes written.
Warning: failed to write 1 - 45 (183 bytes)
Section: 2
- Key: 0, size 448 bytes written.
Section: 4
- Key: 1, size 80 bytes written.
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 9, size 5 bytes written.
- Key: 26, size 132 bytes written.
- Key: 28, size 2 bytes written.
Section: 8
- Key: 0, size 12 bytes written.
- Key: 1, size 12 bytes written.
- Key: 2, size 128 bytes written.
- Key: 3, size 128 bytes written.
- Key: 7, size 8 bytes written.
- Key: 8, size 8 bytes written.
- Key: 9, size 16 bytes written.
Section: 11
- Key: 0, size 4 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 1 byte written.
- Key: 5, size 6 bytes written.
- Key: 6, size 1 byte written.
- Key: 7, size 2 bytes written.
- Key: 8, size 2 bytes written.
- Key: 9, size 2 bytes written.
- Key: 10, size 2 bytes written.
- Key: 11, size 2 bytes written.
- Key: 12, size 1 byte written.
- Key: 13, size 1 byte written.
- Key: 14, size 1 byte written.
- Key: 15, size 1 byte written.
- Key: 16, size 1 byte written.
- Key: 17, size 1 byte written.
- Key: 18, size 1 byte written.
- Key: 19, size 2 bytes written.
- Key: 20, size 2 bytes written.
- Key: 21, size 1 byte written.
- Key: 22, size 1 byte written.
- Key: 23, size 4 bytes written.
- Key: 24, size 4 bytes written.
- Key: 25, size 2 bytes written.
- Key: 26, size 2 bytes written.
- Key: 27, size 2 bytes written.
- Key: 29, size 1 byte written.
- Key: 30, size 1 byte written.
- Key: 31, size 1 byte written.
- Key: 32, size 1 byte written.
- Key: 33, size 1 byte written.
- Key: 34, size 1 byte written.
- Key: 35, size 1 byte written.
- Key: 36, size 1 byte written.
- Key: 37, size 1 byte written.
- Key: 38, size 2 bytes written.
- Key: 39, size 2 bytes written.
- Key: 40, size 2 bytes written.
- Key: 41, size 2 bytes written.
- Key: 42, size 2 bytes written.
- Key: 43, size 4 bytes written.
- Key: 44, size 4 bytes written.
- Key: 45, size 4 bytes written.
- Key: 46, size 1 byte written.
- Key: 47, size 16 bytes written.
- Key: 48, size 2 bytes written.
- Key: 49, size 2 bytes written.
- Key: 50, size 20 bytes written.
- Key: 51, size 10 bytes written.
- Key: 52, size 2 bytes written.
- Key: 53, size 20 bytes written.
- Key: 54, size 10 bytes written.
- Key: 55, size 1 byte written.
- Key: 56, size 1 byte written.
- Key: 57, size 1 byte written.
- Key: 58, size 1 byte written.
- Key: 59, size 1 byte written.
- Key: 60, size 1 byte written.
- Key: 61, size 1 byte written.
- Key: 62, size 1 byte written.
- Key: 63, size 1 byte written.
- Key: 64, size 1 byte written.
- Key: 65, size 1 byte written.
- Key: 66, size 32 bytes written.
- Key: 67, size 32 bytes written.
- Key: 68, size 2 bytes written.
- Key: 69, size 2 bytes written.
- Key: 70, size 2 bytes written.
- Key: 71, size 2 bytes written.
- Key: 72, size 2 bytes written.
- Key: 73, size 2 bytes written.
- Key: 74, size 2 bytes written.
- Key: 75, size 2 bytes written.
- Key: 76, size 2 bytes written.
- Key: 77, size 2 bytes written.
- Key: 78, size 2 bytes written.
- Key: 79, size 2 bytes written.
- Key: 80, size 2 bytes written.
- Key: 81, size 2 bytes written.
- Key: 82, size 2 bytes written.
- Key: 83, size 2 bytes written.
- Key: 84, size 2 bytes written.
- Key: 85, size 2 bytes written.
- Key: 86, size 2 bytes written.
- Key: 87, size 2 bytes written.
- Key: 88, size 2 bytes written.
- Key: 89, size 2 bytes written.
- Key: 90, size 2 bytes written.
- Key: 91, size 2 bytes written.
- Key: 92, size 2 bytes written.
- Key: 93, size 2 bytes written.
- Key: 94, size 2 bytes written.
- Key: 95, size 2 bytes written.
- Key: 96, size 2 bytes written.
- Key: 97, size 2 bytes written.
- Key: 98, size 2 bytes written.
- Key: 99, size 2 bytes written.
- Key: 100, size 2 bytes written.
- Key: 101, size 2 bytes written.
- Key: 102, size 2 bytes written.
- Key: 103, size 2 bytes written.
- Key: 104, size 2 bytes written.
- Key: 105, size 2 bytes written.
- Key: 106, size 2 bytes written.
- Key: 107, size 2 bytes written.
- Key: 108, size 2 bytes written.
- Key: 109, size 2 bytes written.
- Key: 110, size 2 bytes written.
- Key: 111, size 2 bytes written.
- Key: 112, size 2 bytes written.
- Key: 113, size 2 bytes written.
- Key: 114, size 2 bytes written.
- Key: 115, size 2 bytes written.
- Key: 116, size 4 bytes written.
- Key: 117, size 4 bytes written.
- Key: 118, size 1 byte written.
- Key: 119, size 4 bytes written.
- Key: 120, size 4 bytes written.
- Key: 121, size 4 bytes written.
- Key: 122, size 4 bytes written.
- Key: 123, size 16 bytes written.
- Key: 124, size 4 bytes written.
- Key: 125, size 2 bytes written.
- Key: 126, size 2 bytes written.
- Key: 127, size 1436 bytes written.
Section: 12
- Key: 0, size 102 bytes written.
Section: 31
- Key: 4, size 20 bytes written.
Section: 44
- Key: 0, size 1 byte written.
Section: 50
- Key: 0, size 2 bytes written.
Section: 54
- Key: 2, size 24 bytes written.
Section: 88
- Key: 0, size 36 bytes written.
Section: 96
- Key: 0, size 24 bytes written.
Section: 107
- Key: 0, size 21 bytes written.
- Key: 1, size 79 bytes written.
- Key: 2, size 79 bytes written.
- Key: 3, size 70 bytes written.
- Key: 25, size 132 bytes written.
- Key: 26, size 12 bytes written.
Section: 117
- Key: 1, size 3 bytes written.
- Key: 2, size 6 bytes written.
- Key: 3, size 1 byte written.
- Key: 4, size 9 bytes written.
- Key: 5, size 10 bytes written.
- Key: 6, size 8 bytes written.
- Key: 8, size 42 bytes written.
- Key: 13, size 3 bytes written.
- Key: 14, size 3 bytes written.
- Key: 16, size 40 bytes written.
- 120 skipped
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 9, size 64 bytes written.
Section: 208
Section: 217
- Key: 0, size 32 bytes written.
- 239 skipped
- 308 skipped
Section: 309
Warning: failed to write 309 - 0 (5 bytes)
Warning: failed to write 309 - 1 (3 bytes)
Warning: failed to write 309 - 2 (13 bytes)
Warning: failed to write 309 - 4 (13 bytes)
Warning: failed to write 309 - 5 (13 bytes)
Warning: failed to write 309 - 7 (13 bytes)
Warning: failed to write 309 - 8 (13 bytes)
Warning: failed to write 309 - 17 (13 bytes)
Warning: failed to write 309 - 22 (13 bytes)
Section: 313
- Key: 0, size 615 bytes written.
Section: 322
Section: 334
Section: 341
- Key: 4, size 4514 bytes written.
Section: 354
- Key: 0, size 18 bytes written.
Section: 356
- Key: 1, size 8 bytes written.
Completed in 24.125 s
Ok chưa?quăng log scan lên xem sao.![]()
em Read ra rồi nhưng em không piss lấy file 308 ở trong Wiew ra kiể gì... chỉ em với
vẫn thế
Imei plain: 35150204654340-1
Product code: 0590148
Battery voltage: 4731 mV, current: 7 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Phone version(510.21.010) outdated, latest version on server is: 42.0.004
Imei net: 351502046543401
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
