Kết quả 1 tới 10 của 11
    Thành viên chính thức thaibao113's Avatar
    Mặc định 2690 rớt nước mất nguồn xin giúp ..
    máy rớt nước mất nguồn không có dao động . đã vệ sinh rồi ... còn đây là blog e chek với info .
    JAF version 1.98.62
    Detected PKEY: 9002CF6B
    Card life counter: 51.92%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
    USB Cable Driver version: 7.1.78.0
    Changing mode...Done!
    Booting phone...
    Error sync the phone...
    Booting phone...
    FAST PHONE detected!
    CMT Boot Data:
    Asic ID: 000000010000022600010006030C192101033000
    Asic Mode ID: 00
    Asic EM ID: 00000B22
    Asic Public ID: 1240010EA346515060465020A225F883374D93AA
    HASH: 9DDBFCFE6E73CED7D8C6268C8EB8572300000000
    ROM ID: 273F6D55DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 89820089 <=> INTEL -> Type not in database
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 10.10
    22-04-10
    RM-635
    (c) Nokia
    HW version: 1001
    PCI version:
    RFIC version:  06540601
    DSP version:
    ICPR72_10w06
    LCD version: SUEZ
    PPM version: V 10.10
    22-04-10
    RM-635
    (c) Nokia
    V
    Retu version: 16
    Tahvo version: 22
    Content Pack version: Content: v_black
    V 10.10
    22-04-10
    RM-635
    (c) Nokia
    Production serial number: DTF329540
    Product code: 0592103
    Module code: 0204767
    Basic production code: 059C5Z2
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 353754043587695
    IMEI spare to net: 3A 35 57 04 34 85 67 09
    IMEI SV to net: 33 35 57 04 34 85 67 59 F8
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-635.ini
    Setting local mode...
    Reading product code...
    Product Code: 0592103
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-635\
    Checking path: \Products\RM-635\
    No ini files found...
    Done!
    Thành viên kỳ cựu setot_thoi's Avatar
    Aug 2007
    Sóc Trăng
    Log đẹp . đem qua Box khác Flash cái Ver cao xem sao
    MẩnMobile .Y/H : Jimmyphong10
    Thành viên tích cực tkgsm's Avatar
    May 2012
    cho vào hwk mà flash với ver cao nhất xem
    Jun 2012
    fá h bằng cáp vã hôp khác xem ntn kiếm cái v cao nhât luôn nha
    Thành viên chính thức nguyencong3979's Avatar
    Nov 2011
    đả thay thạch anh,làm lại ic nguôn đi bạn....
    Thành viên mới airblade's Avatar
    Aug 2012
    log đẹp lung linh . kẹp nguồn và bấm phím nguồn ko có dao động sao bạn ko nghĩ đến trường hợp mất áp phím nguồn nhỉ ? ? ? .
    Thành viên mới ku_bin_bip's Avatar
    Aug 2012
    thay ic nguồn là ok 100% 2690
    Thành viên tích cực laothanh's Avatar
    Đo xem phím nguồn có áp k.k thì làm theo cái này
    Thành viên kỳ cựu KUNEK_GSM™'s Avatar
    Jun 2011
    THIẾU LÂM TỰ
    bấm nguồn hok có dao động thì coi lại áp nguồn và tiếp xúc pin
    NGỌC NĂNG SERVICE LÂM HÀ-LÂM ĐỒNG
    CHUYÊN : unlock repair update Firmware tiếng việt ALL MOBILE
    Y/H nangngocdao09@yahoo.com
    SDT:0977+1+7+1+0+3+7
    TK AGRIBANK 5404205189059
    Vi phạm nội quy công chức_mobile's Avatar
    May 2012
    lạng sơn
    coi áp tại phím nguồn có ko bạn
  1. 2690 mất nguồn cần giúp
    By dangthanhtra in forum BB5
    Bài viết cuối: 03-03-2013, 19:30
  2. 2690 mất nguồn nhờ ae giúp gấp
    By HQDuan_GSM in forum BB5
    Trả lời: 13
    Bài viết cuối: 05-07-2012, 13:43
  3. 2690 ăn nguồn sau cần ae giúp
    By daochikien in forum BB5
    Trả lời: 21
    Bài viết cuối: 11-05-2012, 09:16
  4. Trả lời: 11
    Bài viết cuối: 14-09-2011, 08:51
  5. 2690 ăn nguồn cần giúp
    By quangthuan257 in forum BB5
    Bài viết cuối: 27-07-2011, 12:19
