Kết quả 1 tới 8 của 8
    Thành viên tích cực daochikien's Avatar
    Mar 2012
    hai duong
    Mặc định 7230 contac cần ae giúp
    em nhận khách con 7230 rơi nước đã làm lên nguồn nhưng dùng được một lúc báo contac , em check bằng ATF thì báo như này các bác xem rồi giúp hộ em với
    Booting Phone via FBUS...
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded First Time
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00000001
    ID DWORD 3 : 020C1921
    ID DWORD 4 : 02044100
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00001040
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00001030
    4 PUBLIC_ID 12
    ID DWORD 0 : 32700101
    ID DWORD 1 : 51A85540
    ID DWORD 2 : E5CB6AD8
    ID DWORD 3 : 0B717DBE
    ID DWORD 4 : 42805B13
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 67E82268
    CRC 1 : F29CEA60
    Checksum 27
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg
    Boot File - Version 011.048.00
    Boot File - Revision 0x0003 (3)
    eBB5ProtocolType == New
    PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
    PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
    Secondary Loader Sent...
    TransmissionTypeRequest_DCT5_NewProtocol
    TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
    FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
    Transmission Type Request Sent...
    ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
    MessageID : 06
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> not detected
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Device ID : 0000 -> BAD FLASH TYPE
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> not used
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 0098 ->
    Device ID : 0030 -> Type not in database
    Revision ID : 0131
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.6
    Checksum : 7C
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files MuxOneNAND (03) ManID :0098 DevID :0030 ExtID :0000 RevID :0131
    Flash Descriptor
    Device ID : 0030
    Revision ID : 0000
    Size : 08000000 (128 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_XSR17_alg.fg
    Algorithm File - Version 011.048.00
    Algorithm File - Revision 0x0003 (3)
    SendAlgoCodeFile_DCT5 : Error
    Try TO UNPLUG RJ45 AND TRY AGAIN
    ERROR: FBUS Boot FAILED
    Quân đến thì tướng đánh _ Nước mạnh thì đắp đê...!
    Mar 2012
    nam định
    cho qua mx box rồi quăng log lên xem sao.log chek bằng atf khó đọc quá
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
  3. ( A & T Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    daochikien (24-09-2012)
    Thành viên chính thức manhteen's Avatar
    Jun 2011
    kiến hưng hà đông hà nội
    fbus boot failed.check đã được đâu mà up lên làm gì.kiểm tra kết nối rùi chek lại đi...
    Thành viên chính thức tranminhkhochuoi's Avatar
    Aug 2012
    Long An-Cần Giuôc
    cho nha lau uông thuốc lăc la ok,minh đa lam 1em rôi
    Sep 2008
    vệ sinh kỹ lại lần nữa đi
  7. ( QUỐC MẠNH ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  8. #6
    Mar 2012
    hai duong
    để em làm rồi báo lại các bác sau nha
  9. #7
    Jun 2012
    kt lai cáp nhe bạn
  10. ( NGỌC HÒA_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    daochikien (03-10-2012)
  11. #8
    Mar 2012
    hai duong
    em cho nhà lầu uống viên thuốc lắc , em nó đã ok rồi , may quá , tí nữa là toi . ae nào đi qua đóng topic lại hộ em với nha . thanks
  1. Trả lời: 24
    Bài viết cuối: 15-03-2013, 10:40
  2. 7230 bay mất chân pin cần giúp
    By tiendatmobile2010 in forum BB5
    Bài viết cuối: 10-07-2012, 14:45
  3. xin giúp 7230
    By moicafe in forum BB5
    Trả lời: 14
    Bài viết cuối: 11-06-2012, 16:54
  4. Trả lời: 3
    Bài viết cuối: 25-11-2011, 17:40
  5. Trả lời: 1
    Bài viết cuối: 27-05-2011, 08:41
