    Thành viên mới quochungna's Avatar
    Dec 2009
    Mặc định C3-00 flash bằng phoenix báo lỗi
    Em mới nhận con C3-00 lỗi phần mềm,em chạy bằng mxbox,phoenix rồi mà vẫn không lên!các bác cao tay chỉ giúp em.đây là log của nó khi em chạy bằng phoenix
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    Loading secondary boot code: 14656 bytes
    Secondary boot loaded
    BB Asic Index is: 00
    Asic ID is: 000000000000000022000509200C0000
    EM Asic ID is: 00005361
    EM Asic ID is: 0100E814
    Public ID is: 0000000000CC50CBF9C3ECB9D276148203737DD7
    Asic Mode ID: 00
    Hash: 1B0D74C532CA1C6133940C740E8C786E
    ROM ID: DE56D582BDDE7A3A
    Device type is: 05
    Device Index is: 00
    Manufacturer code: 0000
    Device ID: 0000
    Extended device ID: 0000
    Revision ID: 0000
    Device type is: 04
    Device Index is: 00
    Manufacturer code: FFFF
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 00
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 01
    Device ID: 0001
    Revision ID: 0000
    Device type is: 03
    Device Index is: 00
    Manufacturer code: 00EC
    Device ID: 0030
    Revision ID: 0431
    Loading update server code: 626776 bytes
    Update server loaded
    Asic CMT: Start programming 48783 KB...
    Asic CMT: Programming data sent: 0%
    Asic CMT: Programming data sent: 10%
    Asic CMT: Programming data sent: 20%
    Asic CMT: Programming data sent: 30%
    Asic CMT: Programming data sent: 40%
    Asic CMT: Programming data sent: 50%
    Asic CMT: Programming data sent: 60%
    Asic CMT: Programming data sent: 70%
    Asic CMT: Programming data sent: 80%
    FUR: ALGO reported error in Control Frame. Unable to continue.
    ERROR: Programming error reported for asic CMT
    -- Error Type 0x05
    -- Error Specifier 0x08
    -- Offending Addr 0x00604000
    -- Expected content 0x00004323
    -- Detected content 0x00001090
    Error sending programming command 0x8400A814
    ERROR Sending status request to Algo! 0x8400A814
    Error while programming CMT!
    Error when flashing Algo (0x84012283)
    Unable to flash phone 0x84012283
    Starting to recover the phone
    Recovering phone
    Initializing
    ERROR: Unable to detect device 0x8401F145. Check USB connection
    ERROR: Product recovery failed
    Unable to set the phone to flash mode. Unable to flash.
    All operations completed
    Product flashing aborted
    Dec 2009
    upppppppppppppppppppppppp
    Thành viên tích cực theanhdienbien's Avatar
    Nov 2010
    sỐ nhà 129-tỔ 9-P.Mường Thanh-TP.Điện Biên
    uppppppppp hộ Chủ Thớt Cho ae Vào giúp
    Điện Thoại Di Động Thế Anh
    ĐT:0989757372
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    chua bot dc phone kt hw lại
    May 2011
    Hà Nội City
    Cái này thay cọng usb zin nhé rùi chạy ver khác cao hơn
    Sóc Sơn - Hà Nội
    chuẩn bị thay cặp là vừa !
  1. Trả lời: 5
    Bài viết cuối: 17-06-2013, 13:33
  2. Trả lời: 6
    Bài viết cuối: 20-04-2013, 15:00
  3. Flash X3-02 bằng Phoenix
    By MrTuanFFC in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 12-04-2013, 10:38
  4. Hướng dẫn flash phoenix cho anh em mới
    By UNLOCKDTDD in forum Tool - Soft và phần mềm free!
    Trả lời: 20
    Bài viết cuối: 04-06-2011, 23:13
  5. Trả lời: 0
    Bài viết cuối: 02-02-2010, 01:28
