Kết quả 1 tới 10 của 15
    Thành viên tích cực phamtrung's Avatar
    Mặc định 1208 contactservice
    các bác xem hộ em cái em chạy 1208 nhầm sang 1200 giờ ko lên nguôn nữa mx key va jaf cũng báo lỗi.may khách mang tới bị mỗi mã bảo vệ máy ko bẻ mã đươc em chạy nhầm thì ko lên.chạy lại 1208 cũng vậy luôn
    MCU ID: 0x2292
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    Flashing Done!
    Operation took 0 minutes 25 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Powering the phone...
    Failed! Aborting!
    Failed! Aborting!
    Flashing Done!
    Operation took 0 minutes 26 seconds...
    Failed! Aborting!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
    Checking path: \Products\RH-105\
    No ini files found...
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_04.110
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_04.11mr
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai4.11mr
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    Phone Type:
    Phone Type:
    Phone Type:
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_04.110
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: d9
    Loader is ready...
    MSID: 84577B2EF00144054C168FDC45
    MSID decoded: 3E4EBAE9005082DAA9000000
    FAID: 8AD23DAB0FFC5667141328D7
    Operation took 0 minutes 9 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013AFFFF...
    Erasing area: 013B0000 - 013EFFFF...
    Operation took 0 minutes 41 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 19 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_04.11mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84A30E7D83AB7C916DC579B404
    MSID decoded: 3E4EBAE9005082DAAA000000
    FAID: C6C615866FD960C75107742C
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01240000 - 0124FFFF...
    Erasing area: 01250000 - 0137FFFF...
    Operation took 0 minutes 13 seconds...
    Writing...
    Operation took 0 minutes 10 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai4.11mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013AFFFF...
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 1 minutes 50 seconds...
    Failed! Aborting!
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    xóa full nạp lại . dòng này nạp file cho nhau dc , nhưng phải thay mh
    Thành viên mới honda airblade's Avatar
    Oct 2012
    test cái màn khác. ko hết cho vào box unlock 1 phát là lụm tiền ak`
    Thành viên tích cực Phúc_Cần Thơ's Avatar
    Dec 2008
    Miền GạoTrắng,Nước Trong.
    Kiếm IC nguồn khác đóng vào đi bạn.
    Flash lại
    Dùng TDS Tool read UEM,sau đó mở JAP vào Imei Tool=>chek vào Change UEM,Manual...Write UEM lại.
    Done!
    Sữa Chữa_Unlock_Tiếng Việt => Nạp Phần Mềm All Mobile
    Thành viên chính thức lesuca's Avatar
    Dec 2009
    Màn hình hay bị lỗi lắm,thay thử cái khác đi bạn,không xong múc nguồn
    addnick làm quen nha
    yahoo:ngoisaocodon350260
  6. ( lesuca ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    GSM Bắc Ninh (12-10-2012)
    Vi phạm nội quy GSM Bắc Ninh's Avatar
    đóng nguồn ko hết đóng CPU nhưng đùng wen thay màn
  8. #7
    Thành viên tích cực gsmmientrung's Avatar
    Jan 2012
    Failed! Aborting!
    con này chưa vào dc tesmod khò nhẹ upp nạp lại xem ko dc làm chân upp hoặc thay upp
  9. #8
    Mar 2012
    nam định
    xóa full flash nạp lại-write pm+unlock .1200 và 1208 chạy lộn rồi thay màn hình vẫn ok.
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
  10. #9
    Thành viên chính thức tinhdml's Avatar
    Dec 2010
    Đắk Nông
    Máy còn lên nguồn bị cái mã bảo vệ chủ thớt chạy nhầm 1200 mà đóng lại chi trời...bạn xem lại con trở đôi còn không?mất kiếm con khác bỏ vào(mất con trở này có chạy tới tết conggo cũng không đồng bộ được)
    P&T mobile
    yahoo:minhphuc_mobileT:0965248678
  11. #10
    Mar 2012
    nam định
    trở kép gì chứ.nếu do con trở kép đó thì ko bao giờ check dk .ko check dk thì làm sao chủ theard chạy nhầm thành 1200 dk chứ
    trường hợp do con trở kép loại bỏ
Hiện có 9 người đang xem bài này . Bao gồm : 0 thành viên và 9 khách
  1. C2-00 bị contactservice!
    By tuongduyen8285 in forum DCT4 - WD2
    Bài viết cuối: 12-06-2013, 12:52
  2. 1208 hiện contactservice
    By nokia_tuantu in forum DCT4 - WD2
    Trả lời: 22
    Bài viết cuối: 28-09-2012, 16:08
  3. C2-01 hai sim báo contactservice
    By chienkute654 in forum BB5
    Bài viết cuối: 13-06-2012, 13:04
  4. 7210c contactservice
    By network in forum BB5
    Bài viết cuối: 14-03-2011, 14:08
  5. Trả lời: 10
    Bài viết cuối: 15-09-2009, 11:13
