đây là logo bằng mxbox a/e có cao kiến gì xin giúp
imel vẫn kòn đẹp long lanh
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0845CE6
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0001002C
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: NMWCD, ver: 7.1.32.81
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.37
EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Waiting for USB device removal ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia Asha 200 USB Phonet, PORT_ID: 33BEFC63
Verifying communication to device OK.
Phone type: RM-761 (Nokia 200)
SW version: V 11.56 26-03-12 RM-761 (c) Nokia
Imei plain: 35934604473118-4
Product code: 059K957
Detected as DCT4 phone, check Generation selection !
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 06150123005023, ver:
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35934604473118
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
Market items is empty, please select the correct products path !
