Using device: USB ROM and HTI, FW ver: 00.50, SN: 01004029
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Processing MCU file: rm561__09.98.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 27300116413103567294F7441082BBE1B098A6D2
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 28D3B054
Verifying communication to device OK.
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF] erased in 0.578 s
CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.578 s
CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.062 s
CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.188 s
CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 15.719 s
CMT FLASH,NOR area [01380000-0151FFFF] erased in 7.156 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 1 min 32.812 s
Processing PPM file: rm561__09.98.ppm_v
[BB5,BB5 ALGORITHM] size: 6.90 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF] erased in 36.875 s
Programming completed in 33.687 s
Processing CNT file: rm561__09.98.image_v_blac
[BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 16.094 s
CMT FLASH,NOR area [02160000-03FBFFFF] erased in 2 min 13.313 s
Programming completed in 1 min 3.828 s
Total time for flashing process(boot+erase+write) was 8 min 22.625 s
Waiting for device boot up ...
Open device failed: FFFFFFFF (4) The system cannot open the file
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
Market items is empty, please select the correct products path !
không bit có phải lỗi cặp không
