Kết quả 1 tới 9 của 9
    Thành viên tích cực hiep dien thoai's Avatar
    Nov 2007
    Mặc định 2700 xin anh em giúp cho
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 01004029
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.75
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
    Processing MCU file: rm561__09.98.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 117001116BB102566E743B68F92D0D195CA89A8C
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROM ID: 273F6D55DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x3900 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 28D3B054
    Verifying communication to device OK.
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.672 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.656 s
    CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.875 s
    CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.719 s
    CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 42.312 s
    CMT FLASH,NOR area [01380000-0151FFFF] erased in 9.281 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 1 min 8.344 s
    Processing PPM file: rm561__09.98.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.90 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF] erased in 47.281 s
    Programming completed in 24.531 s
    Processing CNT file: rm561__09.98.image_v_blac
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 23.546 s
    CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 3.125 s
    Programming completed in 47.625 s
    Total time for flashing process(boot+erase+write) was 9 min 11.906 s
    Waiting for USB device arrival ...OK
    Device connected: nmwcdc\Nokia 2700 classic USB Phonet, PORT_ID: FFF1B3B
    Phone type: RM-561 (Nokia 2700 classic)
    SW version: V 09.98 06-09-10 RM-561 (c) Nokia
    Imei plain: 35484904298677-0
    Product code: 0592505
    Battery voltage: 3798 mV, current: 142 mA
    Language Pack:
    - not available.
    SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
    warning: avoid SW Downgrade & manual erase to this phone !
    Camera config: NIMMIIIIRRFF00000000, ver: XXX.XXX
    warning: DCC corrupted !
    SIMLOCK invalid!
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST failed!
    SECURITY_TEST passed
    SIMLOCK_DATA corrupted!
    Market items is empty, please select the correct products path !
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    có bk pm full thì nạp vào k thì thây cặp thôi
    Nov 2007
    không có bk khơi động có sim báo contac tắt nguồn không sim khởi động đên lúc chấp nhận thíg tắt
    Thành viên chính thức sau666_gsm's Avatar
    BÌNH DƯƠNG
    kiếm cặp khác thay đi cho nhanh
    Muốn thành công phải qua nhiều thất bại
    Trên đường đời có dại mới lên khôn !
    nam định
    ko backup up thì thay cặp đi.đang gặp con 5130 bị y chang mà chưa có cặp thay đây
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
    không bk thì thay cặp la ok
    Thành viên mới ducduanpr's Avatar
    con này mình làm rồi nó bi lỗi ic nguồn rồi thay con khác là ok
    Thành viên tích cực trong_mobile's Avatar
    Jun 2012
    Bệnh e nó rồi Thay nguyên cặp ok............
    Jun 2012
    simlock rồi thay căp cho nhanh dư 1 men 300k dc pm chử kí nhé
  1. 2700 cần giúp
    By yenbai in forum BB5
    Bài viết cuối: 27-07-2012, 08:18
  2. 2700 cần giúp đở
    By sonfa139 in forum BB5
    Bài viết cuối: 28-12-2011, 18:13
  3. 2700 Xin giúp
    By banhkeohaiha in forum BB5
    Trả lời: 12
    Bài viết cuối: 24-11-2011, 11:17
  4. 2700 bệnh lạ nho a e giúp
    By anhtaia3 in forum BB5
    Trả lời: 16
    Bài viết cuối: 04-08-2011, 17:58
  5. 2700 cần giúp gấp
    By vinhattieu in forum BB5
    Bài viết cuối: 24-12-2010, 14:09
