ATF Software Version v9.15
ATF Box FBUS Flash Started...
Number of Image Files: 4
Forcing Test Mode via BUSCHECK...
Booting Phone via FBUS...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 400C1921
ID DWORD 4 : 01051103
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 1E400103
ID DWORD 1 : 45A40052
ID DWORD 2 : 7C76BC5C
ID DWORD 3 : E432F53C
ID DWORD 4 : 9532572F
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 17
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
Boot File - Version 012.08.00
Boot File - Revision 0x0002 (2)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MessageID : 06
SubBlocks : 06
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0400 -> Flash
Device ID : 0000 -> Type not in database
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0050 -> Type not in database
Revision ID : 0031
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.5
Checksum : 06
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0050 ExtID :0000 RevID :0031
Flash Descriptor
Device ID : 0050
Revision ID : 0000
Size : 20000000 (512 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g
Algorithm File - Version 012.08.00
Algorithm File - Revision 0x0002 (2)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
PAPUB_KEYS_HASH_REQ_BB5
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
E00DA77BF32983F864BC7671FE7709A29D8E2C08
Scanning Simlock Applet Type...
OK
PA_SIMLOC30 Applet detected
Use "Scan Phone" Button to Check if this Phone
uses a 15-digit NCK or a 20-digit NCK...
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Basic Phone Information
WARNING: Simlock Backup Failed
If this is a Dead Phone, just click YES
to Continue with the Flash Procedure...
Changing MODE : FLASH
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 17
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0031
Block Length : 09
Data : XSR 1.5
Checksum : 06
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0050
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
BB Asic Index : 00
CMT PAPUBKEYS HASH:
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
PARTNERC : Empty
Reading : MDM_KEYS (CMT)
MDM_KEYS : Empty
NPC CERTIFICATE INFORMATION (CMT):
IMEI : 345580504586228
PRODUCT CODE : 059B7G5
WLAN ID : 2C2:E7:AE:42:2C
BLUETOOTH ID : 2C2:E7:AE:13:4C
PUBLIC_ID : 1E40010345A400527C76BC5CE432F53C9532572F
PAPUB_KEYS_HASH: E00DA77BF32983F864BC7671FE7709A29D8E2C08
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\354855040852682\3548550408526 82_124554.rpl
Processing Image File :
C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_32.0.002_prd.core.C00
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000 Hz
Algorithm Sending Speed : 13000000 Hz
Program Sending Speed : 13000000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 494
Entry Point : 0x2C1818
Page Format : 128K
Maximum Page Size : 0x00040000
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 17
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0031
Block Length : 09
Data : XSR 1.5
Checksum : 06
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0050
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CRITICAL ERROR ... ALGORITHM LOADER NOT FOUND
Try to Select "Skip HW ID Chk"...
SendAlgoCodeFile_DCT5 : Error
Try TO UNPLUG RJ45 AND TRY AGAIN
Operations Failed....
