chọn file khác chuẫn hon là ok dó bac log dep mà,nghien cuus chọn file di bác
em kẹp main không cũng không lên đươc nguồn bác ah
các bác xem giup em với chiêu mai khách đến lấy rối
bạn xem có chạm ,nong con nào ko.
tháo máy ra kẹp main xem có ok ko
có thể bác phải backup rùi làm con flash đấy
con này em chạy ok hết
Version from phone: 510.21.009
Version from file: 510.21.009
MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C087AD77
Using device: HTI, FW ver: 00.50, SN: 0100A342
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35154904420215_BA CK.rpl).
Processing MCU file: rm343_510.21.009_prd.c00
[BB5,XSR 1.5] size: 68.80 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0790000A7D9A005243D3E25F205485239E6F414F
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 122.56 MB
CMT FLASH,MuxOneNAND area [00040000-007FFFFF]
CMT FLASH,MuxOneNAND area [00A00000-0759FFFF]
CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 96B8EDD5 [RAP Certificate 102 v1] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS*CORE block sent
CMT SOS+ROFS block sent
NAND: OK
Programming completed in 2 min 25.969 s
Processing PPM file: rm343_510.21.009.02U
[BB5,XSR 1.5] size: 15.79 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 64 KB
NAND: OK
NAND: OK
Programming completed in 35.141 s
Processing CNT file: rm343_510.21.009_prd.v16
[BB5,XSR 1.5] size: 27.14 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 33.56 MB
CMT FLASH,MuxOneNAND area [05420000-0759FFFF]
NAND: OK
CMT SOS+ROFX block sent
NAND: OK
Programming completed in 58.266 s
Total time for flashing process(boot+erase+write) was 4 min 29.110 s
Phone type: RM-343 (Nokia E66)
SW version: V ICPR71_09w47.10 20-01-11 RM-343 (c) Nokia
Imei plain: 35154904420215-9
Product code: 0566412
Battery voltage: 4768 mV, current: 13 mA
ApeCoreSw: 510.21.009
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351549044202159
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
con này em chạy phần mềm ok hết thay 2 con nguồn làm lại cpu plash nhưng vẫn về tình trạng ban đầu máy bấm nguồn lên nokia đến giai đoạn chuẩn bi lên đèn no nháy đèn rồi dòng lại về lúc mới bấm nguồn. nó cứ lặp đi lặp lại 3 lần sau mất nguồn
thế bác thay hêt rùi thế con thạch anh thay chưa vậy
Nguyễn Việt Dũng , Cầu Tre - Hồ Sơn - Tam Đảo - VP
YM : viet_dung702 0989 548 748 . STK : 2809205034138 Agribank ,Tam Đảo
thach anh em lấy con 2690 sang vẫn vậy
có lẽ bác backup full rùi thay flash thui,không đc thay luôn nguyên cặp làm mềm ok, nguồn thay rùi gia cố upp va flash rùi không đc chác phải thay thui
nhưng ma log no em nhìn đẹp chác cpu plash không vấn đề gì đâu bác ahf
