bây giờ chạy ver 022.014 thì nó lên nguồn nhưng mà bị banh simlock.chạy ver 111.040.1511 thi lên chữ nokia rồi tối om luôn á.bây giờ em có box ATF và rpl gốc của nó thôi.anh nào có thể giúp em được không.
luôn luôn lắng nghe.lâu lâu mới hiểu!
Number of Image Files: 5
Processing Image File :
RM-626_111.030.0609_79u_prd.core.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 13000000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 601
Entry Point: 0x0214
Page Format : -1
MAX PAGE : 0x00040000
RM-626_111.030.0609_C02.01_SEAP_79u_prd.rofs3.fpsx
CMT Type : BB5
Number of Blocks : 16
Entry Point: 0x00FC
Page Format : -1
MAX PAGE : 0x00004A00
RM-626_111.030.0609_38.01_Vietnam_79u_prd.rofs2.fpsx
CMT Type : BB5
Number of Blocks : 134
Entry Point: 0x00F4
Page Format : -1
RM-626_111.030.0609_U08.01_79u.uda.fpsx
CMT Type : BB5
Number of Blocks : 587
Entry Point: 0x00F4
Page Format : -1
RM626_APE_ONLY_ENO_11w36_v0.037.fpsx
CMT Type : BB5
Program Sending Speed : 6500000Hz
Number of Blocks : 26
Entry Point: 0x0138
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000003
ID DWORD 1 : 00000226
ID DWORD 2 : 00010007
ID DWORD 3 : 600C1921
ID DWORD 4 : 02031104
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00001040
3 EM_ASIC_ID 02
ID DWORD 0 : 00001030
4 PUBLIC_ID 12
ID DWORD 0 : 1E900107
ID DWORD 1 : 43D60344
ID DWORD 2 : 1CE95164
ID DWORD 3 : B3F6D17F
ID DWORD 4 : 61192250
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : E693EF0D
CRC 1 : AC22615B
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
Secondary Loader Sent....
MessageID : C1
SubBlocks : 06
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0020 ->
Device ID : 0068 -> Type not in database
Revision ID : 0031
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Type not in database
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Revision ID : 0031
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.6
Flash Descriptor
Device ID : 0068
Revision ID : 0000
Size : 40000000 (1024 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
START READING RPL DATA
IMEI: 354864042590308
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
Reading : PARTNERC... OK!
NPC CERTIFICATE INFORMATION (CMT):
IMEI : 345680424953080
PRODUCT CODE : 059D0M7
WLAN ID : 78:2E:EF:794
BLUETOOTH ID : 78:2E:EF:79:86:B2
PUBLIC_ID : 1E90010743D603441CE95164B3F6D17F61192250
PAPUB_KEYS_HASH: 8EABFDA6B8A757034233978C16A93B892CE2D4FA
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\354864042590308\3548640425903 08_62824.rpl
Pabub KEY Request
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
ImagePath: D:\NOKIA\Products\RM-626\
ImageFilename: RM-626_111.030.0609_79u_prd.core.fpsx
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000020000FFFFFFFF00000005000000030000 00020014000002A40000000000040000000202B800000D1000 0000000008000000010FC800001E4800000000002700000001 2E100000105000000000000A000000013E60000000400000D9
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x57 (87)
ERASE Blocks : 0x02 (2)
0 ERASE_AREA_BB5 0x12
Block Length : 0x23 (35)
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
0 : 00040000-0007FFFF
1 : 000C0000-008BFFFF
2 : 00DC0000-0FC7FFFF
3 : 2E100000-3E5FFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x03000000
Format Info : 000000000000000A0000000000000002000000640018000000 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5004120B000300000400000007FFFF120B000300000C000000 8BFFFF120B00030000DC00000FC7FFFF120B0003002E100000 3E5FFFFF54
FORMAT_REQUEST_BB5 : 5001192F00030000000003000000000000000A000000000000 00020000006400180000000000020000000100000000000000 0025
Successfully Erased...
Total blocks to write : 601
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : SOS+PMML
>> CMT Rootkey Hash CERT : SOS+DECOMP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [8EABFDA6B8A757034233978C16A93B892CE2D4FA]
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : SOS+IVE3A
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : LDSP
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS+CORE
>> CMT Rootkey Hash CERT : SOS+ROFS1
ImageFilename: RM-626_111.030.0609_C02.01_SEAP_79u_prd.rofs3.fpsx
StartErase_DCT5...
BlockLength : 0x16 (22)
ERASE Blocks : 0x01 (1)
Block Length : 0x13 (19)
Device Index : 0x00
0 : 01378000-0139FFFF
1 : 0E900000-0FC7FFFF
ERASE_REQUEST_BB5 : 5002120B000300013780000139FFFF120B0003000E9000000F C7FFFF5B
Total blocks to write : 16
>> CMT Rootkey Hash CERT : SOS+ROFS3
>> CMT Rootkey Hash CERT : SOS+IVE3B
ImageFilename: RM-626_111.030.0609_38.01_Vietnam_79u_prd.rofs2.fpsx
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 0A580000-0E8FFFFF
ERASE_REQUEST_BB5 : 5001120B0003000A5800000E8FFFFFE1
Total blocks to write : 134
>> CMT Rootkey Hash CERT : SOS+ROFS2
ImageFilename: RM-626_111.030.0609_U08.01_79u.uda.fpsx
StartErase_DCT5...
Device Index : 0x00
0 : 0FC80000-2E0FFFFF
ERASE_REQUEST_BB5 : 5001120B0003000FC800002E0FFFFFCC
Total blocks to write : 587
ImageFilename: RM626_APE_ONLY_ENO_11w36_v0.037.fpsx
StartErase_DCT5...
Device Index : 0x00
0 : 008C0000-00DBFFFF
ERASE_REQUEST_BB5 : 5001120B000300008C000000DBFFFF79
FAILED ERASING....
Flashing Failed....
Booting/Flashing Failed...
Please Try Again...
Ai giup em voi ko
