Tình hình la em mới thay con fash 2700 chạy lại log rất đẹp không lỗi lầm nhưng bật nguồn lên nokia bấm vào menu là contac mất nguồn luôn. imel vẫn đẹp em chạy bằng atf bác nào có ý kiến gì không xin giúp em với.thanks mọi người
ATF Software Version v9.80
ATF Nitro FBUS Flash Started...
Number of Image Files: 3
Processing Image File :
C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 6500000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 1256
Entry Point : 0x5047
Page Format : 128K
Maximum Page Size : 0x00004000
Changing MODE : FLASH
Booting Phone via FBUS...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 24800106
ID DWORD 1 : 648F0F56
ID DWORD 2 : A84C1966
ID DWORD 3 : 453DDFA5
ID DWORD 4 : 5AD15014
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 9A
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version 010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MessageID : 03
SubBlocks : 03
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0001 ->
Device ID : 003F -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 8A21
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : B5
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0001 DevID :003F ExtID :0000 RevID :8A21
Flash Descriptor
Device ID : 003F
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version 010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
PAPUB_KEYS_HASH_REQ_BB5
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
3EA22A1DDA660002E56108DB5072A10F8709443F
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x36 (54)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x33 (51)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 00000000-000006BF
1 : 000006C0-0001FFFF
2 : 00040000-000BFFFF
3 : 000C0000-0013FFFF
4 : 00140000-0137FFFF
5 : 01380000-0151FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
STATUS_REQUEST_BB5...
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:01:12
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing : rm561__09.98.mcusw
Total blocks to write : 1256
FBUS Cable RX2 PIN Diagnostics
Block Length : 01
BB ASIC Index : 00
INFO: RX2 PIN is OK
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [3EA22A1DDA660002E56108DB5072A10F8709443F]
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
Block Length : 01
BB ASIC Index : 00
FlashInfo.RestartMode : 1
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:01:22
Making delay between files for 5000ms
C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_v
CMT Type : BB5
Number of Blocks : 442
Entry Point : 0x00B6
Page Format : 128K
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 9A
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A21
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : B5
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 003F
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
BB Asic Index : 00
CMT PAPUBKEYS HASH:
No RESTORE CERTIFICATE FOUND IN IMAGE FILE
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01520000-01DBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:00:30
Processing : rm561__09.98.ppm_v
Total blocks to write : 442
Block Length : 01
BB ASIC Index : 00
FlashInfo.RestartMode : 2
Time Taken to Flash : 00:00:36
C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.image_v_blac
CMT Type : BB5
Number of Blocks : 872
Entry Point : 0x00C8
Page Format : 128K
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 9A
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A21
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : B5
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 003F
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x16 (22)
Block Length : 0x13 (19)
Device Index : 0x00
0 : 01DC0000-0215FFFF
1 : 02160000-03FBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:02:03
Processing : rm561__09.98.image_v_blac
Total blocks to write : 872
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:01:03
Total Flash Write Time (Flashing Only) : 00:03:02
Total Flashing Time (Booting + Erase + Flashing) : 00:06:51
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Basic Phone Information
MCU Version: V 09.98 06-09-10 RM-561 (c) Nokia
IMEI Plain : 358256042104998
IMEI Spare : A358256042104990
IMEI SV : 33582560421049955F
Phone Model: Nokia 2700 classic
Category : Classic Phone
Phone Type : RM-561
Extended Phone Information
Product Serial Number: 0
Product Code : 0579808
Long Production SN : 0
PPM SW Version : V 09.98 06-09-10 RM-561 (c) Nokia V
BT MCM Version : 2222-302
MCU SW Version : V 09.98 06-09-10 RM-561 (c) Nokia
RFIC Version : 06560601
DSP Version : ICPR72_09w26
LCD Version : SHARP
Content Pack Version : Content: v_black V 09.98 06-09-10 RM-561 (c) Nokia
AHNE Version : 30
RETU Version : 16
TAHVO Version : 22
Bluetooth ID : 48C:FB:5B:52:34
CS Type : GSM850, GSM900, GSM1800, GSM1900
Simlock Information
Unable to read SP Data..
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Phone Type : RM-561
LCD Version : SHARP
AHNE Version : 30
RETU Version : 16
TAHVO Version : 22
Simlock Information
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : NIMMIIIIRRFF094B2F01
DCC Ver: 002009
Status : OK
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
C:FB:5B:52:34
