Kết quả 11 tới 16 của 16
    Thành viên tích cực mrtranquang1993's Avatar
    Mar 2012
    em làm đủ các kiểu rồi nhưng vấn không được.
    May 2012
    máy hiện giờ thế nào rồi chủ xị
    Mar 2012
    Trích Được post bởi satthu_mobile Xem bài viết
    máy bật nguồn dung cái màn hình không kịp sáng sáng mờ rồi tắt.
    Mar 2012
    chạy tất cả đều ok. nhưng không factory riét được.
    Number of Image Files: 3
    Processing Image File :
    rm346_510.21.009_prd.c00
    CMT Type : BB5
    CMT Algorithm : XSR 1.5
    Secondary Sending Speed : 650000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 588
    Entry Point: 0x20270D
    Page Format : -1
    MAX PAGE : 0x00020000
    rm346_510.21.009_prd.v29
    CMT Type : BB5
    Number of Blocks : 186
    Entry Point: 0x0169
    Page Format : -1
    rm346_510.21.009.07U
    CMT Type : BB5
    Number of Blocks : 169
    Entry Point: 0x0122
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    ERROR: BOOTROM NOT DETECTED
    BootFlashMode_DCT5
    READING BOOTROM
    BootFlashModeDCT5Ex Succeded After 2 Tries
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 400C1921
    ID DWORD 4 : 01031103
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 05100118
    ID DWORD 1 : 07568B52
    ID DWORD 2 : 6304927E
    ID DWORD 3 : 72F972C3
    ID DWORD 4 : 4CC04F64
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 4B9B7510
    CRC 1 : 3E691FF8
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_2nd.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0400 -> Flash
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0040 -> Type not in database
    Revision ID : 0121
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.5
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    Size : 10000000 (256 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_XSR15_a lg.fg
    SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
    SendCodeStart_NewProtocol
    SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok...
    TransmissionTypeRequest_DCT5_NewProtocol
    TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 54 04 01 00 00 00 A5
    VPP Enabled by Software
    Using Internal VPP
    FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
    PA PUBLIC KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    52570A2086C79E6965175815B5388535CDD5C6F7
    START READING RPL DATA
    IMEI: 356059039513946
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... EMPTY
    NPC CERTIFICATE INFORMATION (CMT):
    IMEI : 356059039513946
    PRODUCT CODE : 0569999
    WLAN ID : 18:86:AC:24:C5:7A
    BLUETOOTH ID : 18:86:AC:24:29:3A
    PUBLIC_ID : 0510011807568B526304927E72F972C34CC04F64
    PAPUB_KEYS_HASH: 52570A2086C79E6965175815B5388535CDD5C6F7
    CCC CERTIFICATE INFORMATION (CMT):
    HWC CERTIFICATE INFORMATION (CMT):
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\356059039513946\3560590395139 46_83908.rpl
    ImagePath: C:\Documents and Settings\19091993\Desktop\
    ImageFilename: rm346_510.21.009_prd.c00
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    PARTITION_INFO_REQUEST_BB5 : 64012F6F00030000010000FFFFFFFF00000006000000030000 0002000800000158000000000004000000020160000005FA00 000000000800000001075A000007A800000000000B00000001 0F020000001A000000000009000000010F1C00000070000000 00000A000000010F8C000000160000DD
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0xB1 (177)
    ERASE Blocks : 0x04 (4)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x1B (27)
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    0 : 00040000-007FFFFF
    1 : 00A00000-0759FFFF
    2 : 0F1C0000-0F8BFFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x00000000
    Format Info : 000000000000000B0000000000000002000000640000000300 000001000000010000000000000000
    2 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 00000000000000090000000000000001000000640000000400 000001000000010000000000000000
    3 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000
    ERASE_REQUEST_BB5 : 5003120B00030000040000007FFFFF120B00030000A0000007 59FFFF120B0003000F1C00000F8BFFFF5A
    FORMAT_REQUEST_BB5 : 5001192F00030000000000000000000000000B000000000000 00020000006400000003000000010000000100000000000000 003D
    FORMAT_REQUEST_BB5 : 5001192F000300000000000000000000000009000000000000 00010000006400000004000000010000000100000000000000 003F
    FORMAT_REQUEST_BB5 : 5001192F00030000000000000000000000000A000000000000 00020000006400000003000000010000000100000000000000 003E
    Successfully Erased...
    Total blocks to write : 588
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS [52570A2086C79E6965175815B5388535CDD5C6F7]
    >> CMT Rootkey Hash CERT : SOS*UPDAPP
    >> CMT Rootkey Hash CERT : SOS*DSP0
    >> CMT Rootkey Hash CERT : SOS*ISASW
    >> CMT Rootkey Hash CERT : SOS*CORE
    >> CMT Rootkey Hash CERT : SOS+ROFS
    ImageFilename: rm346_510.21.009_prd.v29
    StartErase_DCT5...
    BlockLength : 0x3F (63)
    ERASE Blocks : 0x02 (2)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 05420000-0759FFFF
    Device Index : 0x00
    ERASE_REQUEST_BB5 : 5001120B000300054200000759FFFF39
    Total blocks to write : 186
    >> CMT Rootkey Hash CERT : SOS+ROFX
    ImageFilename: rm346_510.21.009.07U
    StartErase_DCT5...
    BlockLength : 0x32 (50)
    ERASE Blocks : 0x01 (1)
    0 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 00000000000000080000000000000001000000640000000A00 000001000000010000000000000000
    FORMAT_REQUEST_BB5 : 5001192F000300000000000000000000000008000000000000 0001000000640000000A000000010000000100000000000000 003A
    Total blocks to write : 169
    ContinueFlash_DCT5 Complete
    Continue Flash Complete : : No Error - 0 (0x00)
    STATUS_REQUEST_BB5...
    1 Sub Block ID : 15 STATUS_NAND_OK_BB5
    Block Length : 0F
    BB ASIC Index : 00
    Device Type : 03
    Device Type : 00
    Num Bad Blocks : 00000000
    Additional Bad : 00000000
    Correctable ECC : 00000000
    FlashInfo.RestartMode : 1
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:04:06
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    SW: V ICPR71_09w47.10 20-01-11 RM-346 (c) Noki
    CONFIG KEY : 8000000000000000
    PROVIDER KEY : 2342000000000000
    NETWORK NAME : Hutchison 3G UK Ltd;UK [GSM]
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open
    Block [2] 1:Open
    SIMLOCK STATE : Not Locked
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SUPER_DONGLE_TEST : PASSED
    SECURITY_CODE : 12345
    SL1/SL2 Phone detected
    FACTORY SET TO : Full Factory Set
    FAILED
    FACTORY SET TO : User Data
    FAILED
    FACTORY SET TO : Leave Factory
    FAILED
    FACTORY SET TO : Service Center
    FAILED
    FACTORY SET TO : Software Upgrade
    FAILED
    FACTORY SET TO : Production Tune
    FAILED
    ERROR: Active Phone Handle was NOT DETECTED
    TIP: Make sure that Phone USB Connection Mode is
    OVI Suite Mode
    or
    PC Suite Mode
    Mar 2012
    máy đã lên nguồn.
    Thành viên tích cực pakangonline's Avatar
    Phan Thiết - Bình Thuận
    chúc mừng chủ thớt
