    Thành viên mới sellykenmobile's Avatar
    Oct 2012
    Mặc định C5-00 Flash Mất Nguồn
    log: buz check nó báo vầy à bác bác nào giúp em với...:dead:
    MXKEY [MxKey Team HTI PLUS Flasher Interface 5], SN: C0841114
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100A412
    Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed)
    Driver: NMWCD, ver: 7.1.32.75
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
    CMT EM0 ID: 00000C35
    CMT EM1 ID: 00000C30
    CMT PUBLIC ID: 2580020CEE8E0344BA9B3831866ACA7FB4F4A011
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
    CMT ROM ID: E693EF0DAC22615B
    Loading CMT secondary boot code
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
    Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Loading CMT update server data
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
    Update server code loaded.
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2AECE95B
    FUR: Adding Asic CMT as client OK.
    CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
    Selected firmware certificate matched.
    Original Imei: 35379204098346
    Original Product code: 0593549
    Bluetooth ID: D4CBAFE433AA
    SIMLOCK PA identifier:
    [0] PA_SIMLOC30
    Reading CMT NPC (0x168 bytes).
    Reading CMT VARIANT (0x0 bytes).
    Reading CMT CCC (0x160 bytes).
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Reading CMT MDM_KEYS (0x0 bytes).
    Reading CMT PARTNERC (0x0 bytes).
    Waiting for device boot up ...
    Warning: Phone did not reboot to normal mode.
    đây là log flash
    Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100A412
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Processing MCU file: rm645_071.005_prd.core.fpsx
    [BB5,XSR 1.6] size: 96.64 MB
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
    RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35379204098346_CE RT.rpl).
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 170.06 MB
    CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
    CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
    CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT SOS+PMML block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent
    CMT GENIO_INIT block sent
    CMT SOS*UPDAPP block sent
    CMT SOS*DSP0 block sent
    CMT LDSP block sent
    CMT SOS*ISASW block sent
    CMT SOS+CORE block sent
    CMT SOS+ROFS1 block sent
    Programming completed in 19.735 s
    Processing PPM file: rm645_071.005_16.01_Vietnam_prd.rofs2.fpsx
    [BB5,XSR 1.6] size: 30.75 MB
    Erase size: 51 MB
    CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF]
    CMT SOS+ROFS2 block sent
    Programming completed in 8.265 s
    Processing PPM file: rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
    [BB5,XSR 1.6] size: 8.01 KB
    Erase size: 14 MB
    CMT FLASH,MuxOneNAND area [0A040000-0AE3FFFF]
    CMT SOS+ROFS3 block sent
    Programming completed in 0.053 s
    Processing CNT file: RM645_ENO_10wk48v0.001.fpsx
    [BB5,XSR 1.6] size: 2.25 MB
    Erase size: 4 MB
    CMT FLASH,MuxOneNAND area [004E0000-008DFFFF]
    CMT SOS*ENO block sent
    Programming completed in 0.590 s
    Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx
    [BB5,XSR 1.6] size: 1.32 MB
    Erase size: 72 MB
    CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF]
    Programming completed in 0.886 s
    Total time for flashing process(boot+erase+write) was 41.999 s
    log fbus
    Using device: HTI, FW ver: 00.50, SN: 0100A412
    Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
    CMT Data :
    EM0 ID: 00000C35
    EM1 ID: 00000C30
    ASIC MODE ID: 00
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40
    TransmissionMode: DDR&TX2
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569
    Storing certificate [NPC, CCC, HWC, R&D] ...ERROR: Packet Error(0xAA), code 0xA4000002
    Error
    Error while erasing, Result: 00000000000000 , 0
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    cho qua cáp đa năng flash lại xem bạn
    Oct 2012
    Cáp đa năng chạy được 1 lúc lỗi bác à
    Kiểm tra lại cáp và pinout thật kỉ đi anh, dow ver cao nhất về rồi flash lại thử, xem em nó có chịu tỉnh ngủ không, lấy cáp Fbus flash á, chứ USB cứu không nổi em nó đâu !!!
    Oct 2012
    OK đã ok rồi! thanks các bác đã góp ý! dòng C5 này củ chuối thật đó! mod close topic dùm nha
    Thành viên tích cực 246_GMS's Avatar
    chúc mừng thớt
  1. Trả lời: 5
    Bài viết cuối: 15-05-2013, 10:22
  2. e66 mất nguồn do ic flash!
    By NgocTin_Apple in forum BB5
    Bài viết cuối: 16-03-2013, 15:27
  3. Trả lời: 13
  4. 6100 mất nguồn check ok flash mất nguồn
    By kim nhut truong in forum DCT4 - WD2
    Bài viết cuối: 13-12-2009, 21:28
  5. N70 Flash mất nguồn
    By THÔNG THÁI_GSM™ in forum BB5
    Trả lời: 11
    Bài viết cuối: 12-10-2009, 16:14
