tình hình em có con c5.00 mở nguồn báo lỗi " lổi khởi động nguồn liên hệ nơi bán hàng"
em đã flash ver đụng nóc nhưng vẫn no ok( không đồng bộ được) ...may kg backup dc..em wirte RPL vào thì log như thế này :
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0874500
Using device: HTI, FW ver: 00.50, SN: 0100D82E
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
CMT Data :
SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
EM0 ID: 00000C35
EM1 ID: 00000C30
PUBLIC ID: 0750010E27770E49B84B9A6E5FFAB36463BEC058
ASIC MODE ID: 00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Prog.status for Asic CMT ...
NAND: OK
Phone type: RM-645 (Nokia C5-00)
SW version: V ICPR82_10w18.5.2 16-07-10 RM-645 (c) Nokia
Imei plain: 35934503056372-6
Product code: 0593574
Battery voltage: 4636 mV, current: 15 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 359345030563726
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
tình trạng của em nó bây giờ là lên nokia rồi tắt ngay...
e đã flash bằng MX box...hwk..besttool..phonix...đều chỉ lên rung 1 cái mà kg lên nguồn..đã gỡ bỏ con n200 c2007&c2005 rồi kg có gì khả thi..
AE ai có cách hay thì xin bầy cho em với. năm mới mà gặp toàn máy củ chuối....
