Kết quả 11 tới 14 của 14
  1. #11
    Thành viên chính thức letheanh's Avatar
    Usa
    Đây là log của em nó ạ .
    card found: A1B5CCE8
    registered to: CycloneBox
    Connect phone on selected interface...
    Core : v1.51 , FlashEngine : v1.8
    Selected FlashSettings : FullFlash
    Check FlashFiles, Please, wait...
    Files Set for Flashing :
    MCU : RM-356_60.0.003_prd.core.C00
    PPM : RM-356_60.0.003_prd.rofs2.V20
    PPM2 : RM-356_60.0.003_C01_prd.rofs3.fpsx
    CNT : RM-356_60.0.001_026_000_U01.uda.fpsx
    Flashing phone now...
    Check files done...
    -> SWversion check skipped : Dead mode selected
    Dead Mode is Selected
    Waiting for USB device...
    --- Press phone's power button or insert cable & charger! ---
    Connection opened successfully
    Waiting for communication response...
    BootRom : 1st boot ok
    ASIC ID: 000000010000022600010006400C192101031103
    CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB
    EM0 ID: 00000296
    EM1 ID: 00000B21
    PUBLIC ID: 05200109389400528ED395AD465D1626754A4E2A
    ASIC MODE ID: 00
    ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
    ROM ID: 4B9B75103E691FF8
    PatchRAWLoader: Patched OK
    Processing RAWLOADER...
    Processing RAP3NAND ...
    Processing PASUBTOC ...
    Processing PAPUBKEYS...
    Processing UPDAPP ...
    Boot Done!
    TIME : Boot time : 00:00:03
    Reopening the connection...
    Waiting for response: 30
    Waiting for response: 29
    Waiting for response: 28
    Waiting for response: 27
    Waiting for response: 26
    Waiting for response: 25
    ADL -> [2nd] changing...
    ADL Server confirm flashmode!
    ADL : Auth done...
    ADL : ASIC CMT select Ok
    ===Flashing [MCU]===
    Erase : Processing RM-356_60.0.003_prd.core.C00
    Found 5 areas to erase
    Erasing area 0x00040000 - 0x00082FFF, NAND, CMT
    Result: 0000
    Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT
    Result: 0000
    Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT
    Result: 0000
    Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT
    Result: 0000
    Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT
    Result: 0000
    Erase partition 0x0A
    Partition erase Ok
    Partitioning : Ok [5]
    TIME : Erase time : 00:00:00
    Write : Processing RM-356_60.0.003_prd.core.C00
    Total 510 [510/0/0] blocks to write, writing...
    CMT : Writing Hash CERT [ADA]
    CMT : Writing Hash CERT [KEYS]
    CMT : Writing Hash CERT [PRIMAPP]
    CMT : Writing Hash CERT [RAP3NAND]
    CMT : Writing Hash CERT [PASUBTOC]
    CMT : Writing Hash CERT [PAPUBKEYS]
    CMT : Writing Hash CERT [SOS*UPDAPP]
    CMT : Writing Hash CERT [SOS*ENO]
    CMT : Writing Hash CERT [SOS*DSP0]
    CMT : Writing Hash CERT [SOS*ISASW]
    CMT : Writing Hash CERT [SOS+CORE]
    CMT : Writing Hash CERT [SOS+ROFS1]
    TIME : Write time : 00:00:39
    MCU Write done
    ===Flashing [PPM]===
    Erase : Processing RM-356_60.0.003_prd.rofs2.V20
    Found 1 areas to erase
    Erasing area 0x07180000 - 0x0915FFFF, NAND, CMT
    Result: 0000
    Write : Processing RM-356_60.0.003_prd.rofs2.V20
    Total 78 [78/0/0] blocks to write, writing...
    CMT : Writing Hash CERT [SOS+ROFS2]
    TIME : Write time : 00:00:05
    PPM Write done
    ===Flashing [PPM2]===
    Erase : Processing RM-356_60.0.003_C01_prd.rofs3.fpsx
    Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT
    Result: 0000
    Write : Processing RM-356_60.0.003_C01_prd.rofs3.fpsx
    Total 11 [11/0/0] blocks to write, writing...
    CMT : Writing Hash CERT [SOS+ROFS3]
    TIME : Write time : 00:00:00
    PPM Write done
    ===Flashing [CNT]===
    Erase : Processing RM-356_60.0.001_026_000_U01.uda.fpsx
    Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT
    Result: 0000
    Write : Processing RM-356_60.0.001_026_000_U01.uda.fpsx
    Total 29 [29/0/0] blocks to write, writing...
    TIME : Write time : 00:00:02
    CNT Write done
    ADL : End flashing
    ADL : Finalize...
    Flashing done!
    Total flash time : 00:00:49
    Reboot phone now...
    Reading Phone Info....
    Connected phone - Nokia 5800 XpressMusic
    Software Info: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia
    IMEI: 352012048844962
    Ape Version: V 60.0.003
    Product code: 0559676
    Checking...
    SimLock status : SimLock is Ok
    Security status : Security is Ok
    Read Info Done!
    Settings After Flash Defaults...
    ProductTuneSet...OK!
    SwUpgradeSet...OK!
    Product code update...
    Battery voltage is enough for start
    Set phone to Normal mode...
    AfterFlash operations done ;D
    Done!
    Núi Cao CÒn Có Núi Cao Hơn ...
  2. #12
    Usa
    sao không có ai giúp em nữa vậy ạ
  3. #13
    kt 2 ap kt cho cục nam châm vào xem sao ko thì coi lai chỗ bạn vùa làm lên nguồn xem sao mà tình trang lúc đầu có rơi rớt gjf ko bạn
    yh chanyenmobile_led1202
    ctk hà Văn Yên face hachanyen
    sdt zalo..0972444489
    ​Chùm Mua..bán.BB5 và androi cũ
    BỘ ngoại giao trùm các 4r
  4. #14
    V.I.P Lão_Đại's Avatar
    hải phòng
    Log ngon test lại MH và suket ( Bỏ sim vô lấy tay gõ nhẹ góc phải bên phía dưới MH xem có tiếng khởi động không )
  1. 5800 cần giúp
    By giangtam86 in forum BB5
    Trả lời: 12
    Bài viết cuối: 02-11-2012, 20:02
  2. cpu 5800 cần giúp đở
    By madao in forum BB5
    Bài viết cuối: 04-06-2012, 18:31
  3. 5800 cần anh em giúp
    By quoc.khanh00286 in forum BB5
    Bài viết cuối: 30-09-2011, 06:33
  4. 5800 bệnh lạ cần anh em giúp
    By thanhphuek in forum BB5
    Trả lời: 11
    Bài viết cuối: 19-08-2011, 09:11
  5. N 5800 Rớt nước xin giúp ?
    By hoanganh_den in forum BB5
    Bài viết cuối: 29-05-2009, 15:25
