tình trạng em nó rơi cạn,gắn sim báo không hộp lệ banh imaill,aec có cách nào giúp mà khỏi phải thay cặp không.e chưa gặp nên chưa rành bệnh này mong ae chỉ giáo
Causes:
1. Phone don't power on -> Check cable
2. TX pin from phone don't make contact -> Check cable
3. UPP damaged -> change UPP
MCU ID: 0xAAAA
Failed! Aborting!
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Reading...
MCU SW version: V 06.51
13-05-11
RM-647
(c) Nokia
HW version: 1004
PCI version:
UEM version: 1328
UPP version: 8850
LCD version: WIN:SERI:91
NT7542
PPM version: V 06.51
13-05-11
RM-647
(c) Nokia
MR
ADSP SW version: V 06.51\n13-05-11\nRM-647\n(c) NMP\nmr
Production serial number: 9BF1F8AAH
Product code: 0592248
Module code: 0204496
Basic production code: 059J889
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: ????????0000000
IMEI spare to net: FA FF FF FF FF FF FF 0F
IMEI SV to net: F3 FF FF FF FF FF FF 3F F7
Master Code: 5615162613
Failed reading simlock data...
Phone type: RM-647, Software version: 06.51, Language Pack: MR
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-647.ini
Setting local mode...
Reading product code...
Product Code: 0592248
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-647\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-647\
No ini files found...
Done!
