chủ thớt này làm mất công ae quá![]()
các bác ơi, em cũng trường hợp tương tự, ban đầu máy 6303i, máy hiện nokia nháy sáng rồi tắt, chạy lại ok rồi thì nó hỏi k cần sim để mở máy, ấn accept thì nó báo contact luôn. giúp em nhé!
Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
Loading secondary boot code: 15040 bytes
Secondary boot loaded
BB Asic Index is: 00
Asic ID is: 000000010000022600000001020C192102054100
EM Asic ID is: 00001040
EM Asic ID is: 00001030
Public ID is: 13F00002F2820E49A5937B063950E2325953E004
Asic Mode ID: 00
Hash: 7B045400E1752022F9EB80B0DEA9C65D
ROM ID: 67E82268F29CEA60
Device type is: 05
Device Index is: 00
Manufacturer code: 0000
Device ID: 0000
Extended device ID: 0000
Revision ID: 0000
Device type is: 04
Device Index is: 00
Manufacturer code: FFFF
Device ID: 0000
Revision ID: 0000
Device type is: 00
Device Index is: 00
Device ID: 0000
Revision ID: 0000
Device type is: 00
Device Index is: 01
Device ID: 0001
Revision ID: 0000
Device type is: 03
Device Index is: 00
Manufacturer code: 00EC
Device ID: 0030
Revision ID: 0321
Loading update server code: 634586 bytes
Update server loaded
Asic CMT: Start programming 57593 KB...
Asic CMT: Programming data sent: 0%
Asic CMT: Programming data sent: 10%
Asic CMT: Programming data sent: 20%
Asic CMT: Programming data sent: 30%
Asic CMT: Programming data sent: 40%
Asic CMT: Programming data sent: 50%
Asic CMT: Programming data sent: 60%
Asic CMT: Programming data sent: 70%
Asic CMT: Programming data sent: 80%
Asic CMT: Programming data sent: 90%
Asic CMT: Programming data sent: 100%
Programming complete
Asic CMT: Verifying communication to device...
Mobile device flashing completed.
Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Communication verified
Product code changed
Doing factorysets
Factorysets complete
Reading Dynamic Camera Configuration ID 1
Updating configuration of camera with ID 1
Dynamic Camera Configuration updating failed: 0x84167501 - AudioVisual: No configuration file matching the camera name string NI00IIIIRR0300000000 was found.
Loading default data to phone
Getting Data Package
Reading product state
Starting backup/restore sub-procedure: data item pre-delay
data item pre-delay
data item pre-delay
Sub-procedure completed: Succeeded., result code: 0
Starting to backup/restore data item: ProductProfile, version: 1.1
Data Item backup/restore completed: Succeeded., result code: 0
Starting backup/restore sub-procedure: data item post-delay
data item pre-delay
data item pre-delay
Starting to backup/restore data item: ISSVariantActivator, version: 1.0
data item pre-delay
data item pre-delay
Starting to backup/restore data item: DateTimeSettings, version: 1.0
Backup/restore result: 0 out of 3 items were not backed up
Default data loading complete
Stopping all operations, returning phone to default mode
All operations completed
Firmware updating succeeded.
ZZ--help--ZZ (22-07-2013)
