Number of Image Files: 3
Processing Image File :
rm843__05.85.mcusw
CMT Type : XG223
CMT Algorithm : XG223_V0 ALG
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 90
Entry Point: 0x037D
Page Format : -1
MAX PAGE : 0x00080000
rm843__05.85.ppm_v
CMT Type : XG223
Number of Blocks : 15
Entry Point: 0x0368
Page Format : -1
rm843__05.85.image_v_059N977
CMT Type : XG223
Number of Blocks : 84
Entry Point: 0x00B5
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 82 (0x52) bytes returned
Number of Sub Blocks 5 (0x05)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000C20
ID DWORD 1 : 16100040
ID DWORD 2 : 49922A09
ID DWORD 3 : 829AE9A8
ID DWORD 4 : A1615900
2 PUBLIC_ID 12
ID DWORD 0 : FAC3E9B1
ID DWORD 1 : 0D181543
3 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
4 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 12 5F C7 26 05 B5 C4 E4 8A 9E 02 25 08 4D 25 79
5 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 53588225
CRC 1 : 2F54C676
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usb2nd.fg
Secondary Loader Sent....
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usbalg.fg
Algorithm Loader Sent....
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
START READING RPL DATA
NPC is Corrupted...
ERROR: NPC is Corrupted..., 3
RPL Backup is Skipped
PA PUBLIC KEY Request
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
42E7CDDAAE2ACD72926AC996E98AEC576D7840C3
ImagePath: E:\FILE FLASH NOKIA\309 RM-843\viet 5.85\
ImageFilename: rm843__05.85.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x2E (46)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x2B (43)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 40000000-4003FFFF
1 : 47E00000-47E3FFFF
2 : 400A0000-4251FFFF
3 : 42520000-4261FFFF
4 : 47E40000-47F1FFFF
ERASE_REQUEST_BB5 : 5005120B000000400000004003FFFF120B00000047E0000047 E3FFFF120B000000400A00004251FFFF120B00000042520000 4261FFFF120B00000047E4000047F1FFFF28
Successfully Erased...
Total blocks to write : 90
>> CMT Rootkey Hash CERT : ISSW
>> CMT Rootkey Hash CERT : MEMSET
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : LOADER
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [42E7CDDAAE2ACD72926AC996E98AEC576D7840C3]
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : MCUSW
ImageFilename: rm843__05.85.ppm_v
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 42620000-42FFFFFF
ERASE_REQUEST_BB5 : 5001120B0000004262000042FFFFFFFE
Total blocks to write : 15
ImageFilename: rm843__05.85.image_v_059N977
StartErase_DCT5...
Device Index : 0x00
0 : 43000000-47DFFFFF
ERASE_REQUEST_BB5 : 5001120B0000004300000047DFFFFF7A
Total blocks to write : 84
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
FlashInfo.RestartMode : Test Mode
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:37
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
SW: V 05.85 23-10-12 RM-843 (c) Nokia
IMEI: 12345610654321?
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SUPER_DONGLE_TEST : FAILED
> REPAIR USING FBUS CABLE
> Try "Customized SX4 with SD Repair"
> Then Write PM 1 and 309
SECURITY_CODE : 12345
SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
Life timer data is not yet used...
Life timer: ----:--
mình nghĩ máy bị banh ime , bỏ sim vào máy báo phone restricted, to make ẻmgency call press send key ae nào đã gặp wa xin giúp , máy khách đêm đến nói máy có rớt nước sáy nước song mở nguôn lên mình thấy màn hình tối thui nhưng vẫn còn nguồn , mình lắc ic cũng ko đc mình bỏ vô hộp atf chạy lên giờ nó bị vây luôn xin ae giúp với![]()
