tình hình nhận thằng này mất sóng.test máy ok hết.tháo cặp nó ra đóng qua main xác đẹp của mình(lỗi cặp).vì ngại đóng PA 2700c.đóng qua ok sóng gió như sóng thần.mà xái tí là trắng MH.điên đâu backup.xóa full.thay flash khác.xong nạp lại.cũng yk chang.chạy rất nhiều ver đụng nóc khác nhau cũng ko ok.thao ổ thẻ+camera ko ok.đóng cặp ic nguồn khác ko ok.mong ae cho ý kiến còn con nào nữa múc lun cho rồi.
log check này ae
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087C5B9
Using device: HTI, FW ver: 00.50, SN: 0100E833
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0E000103074A8E569851F976C0C0A653797266C4
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F
TransmissionMode: DDR&TX2
Selected firmware certificate matched.
Original Imei: 35199404183328
Original Product code: 0579808
Bluetooth ID: 5C57C8974899
SIMLOCK PA identifier:
[0] PA_SL3
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35199404183328-5
Battery voltage: 4595 mV, current: 51 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NIMMIIIIRRFF00000000, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351994041833285
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
đây la log info
Battery voltage: 4828 mV, current: 21 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
log trên là mình ko gắn camera nhá.mong ae cho ý kiến
 LinkBack URL About LinkBacks
			 2700c cần ae cho ý kiến
