Kết quả 1 tới 3 của 3
    Thành viên chính thức thaibao113's Avatar
    Mặc định xin giúp nokia 200 hay bị đơ .
    xem dùm e cai log . bây h lên nokia rui tắt .
    Processing Image File :
    rm761__11.95.mcusw
    rm761__11.95.ppm_v
    rm761__11.95.image_v_059J514
    []: Found 1 active devices.
    [Nokia USB Phonet]: Opening Connection
    [Nokia USB Phonet]: Port opened OK!
    SW: V 11.81 20-08-12 RM-761 (c) Nokia
    IMEI: 358259048152623
    START FULL PM BACKUP
    Please Wait...
    Reading : PM 0~400... OK!
    FULL PM Backup Saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\358259048152623\USB_FULL_BACK UP_V 11.81 20-08-12 RM-761 (c) Nokia_358259048152623__11540.pm
    Reading Battery Value : 3784 mV
    Rebooting Phone...
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    Infineon USB Boot: F00A1FB300020303010100FF
    Sending PBL...
    PBL Successfully Sent...
    Sending SBL...
    SBL Successfully Sent...
    Setting Transmission Speed Done...
    Flash Chip Manufacturer: Intel Electronics Corp.
    Flash Boot Successful...
    Unique Data: 0290040195131818
    Original Product Code: 059J514
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : NPC... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\358259048152623\3582590481526 23_11548.rpl
    Data Sections : 04
    Current File : rm761__11.95.mcusw
    Compile Name: rm761__11.95.mcusw_ebl_psi.fls
    Image Type : Main Firmware
    Data Size : 26480008 Bytes
    Sending Certificate Block
    FIRMWARE Certificate Block Sent Successfully...
    Processing Section 01
    FIRMWARE Erase Block: 0x40000000~0x4001FFFE
    Start Erasing...
    Erasing Please Wait...
    Block Erase Done...
    Preparing Data Blocks...
    Data Size: 131072 bytes
    Data Checksum: C1BC
    Uploading Data Blocks to phone...
    Block Write Successful...
    FIRMWARE Data Blocks uploaded to phone...
    Processing Section 02
    FIRMWARE Erase Block: 0x40040000~0x4005FFFE
    Start Erasing...
    Block Erase Done...
    Data Checksum: 7A7A
    Processing Section 03
    FIRMWARE Erase Block: 0x40060000~0x4015FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 1048576 bytes
    Data Checksum: 9313
    Processing Section 04
    FIRMWARE Erase Block: 0x40280000~0x41A7FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 25165824 bytes
    Data Checksum: 769C
    Processing Section 05
    FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
    Start Erasing...
    Block Erase Done...
    Data Verification Successful...
    Data Sections : 01
    Current File : rm761__11.95.ppm_v
    Compile Name: package_v.ppm_ebl_psi.fls
    Image Type : PPM Image
    Data Size : 6706364 Bytes
    PPM Certificate Block Sent Successfully...
    PPM Erase Block: 0x41A80000~0x421BFFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 6703020 bytes
    Data Checksum: 0CE6
    PPM Data Blocks uploaded to phone...
    Data Sections : 01
    Current File : rm761__11.95.image_v_059J514
    Compile Name: package_v_059J514.image.fls
    Image Type : CONTENT Package
    Data Size : 16518416 Bytes
    CONTENT Certificate Block Sent Successfully...
    CONTENT Erase Block: 0x421C0000~0x43E1FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 16515072 bytes
    Data Checksum: 611D
    CONTENT Data Blocks uploaded to phone...
    CONTENT Erase Block: 0x43E60000~0x43F3FFFE
    Start Erasing...
    Block Erase Done...
    Total Flashing Time (Erase + Flashing) : 00:05:45
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    WARNING: Phone is not in the Required Mode...
    Disconnect the Phone and Power it Up Manually.
    Scanning USB Ports...
    ERROR: Active Phone Handle was NOT DETECTED
    TIP: Make sure that Phone USB Connection Mode is
    OVI Suite Mode
    or
    PC Suite Mode
    Make sure you have installed the
    COMPLETE Flash Package for this Phone...
    Goto "Settings" --> "Nokia Settings" and verify that
    the Folder where you installed your Flash Files are
    in the "PRODUCT PATH TO SCAN" List...
    Moderator ThinhPhat_GSM's Avatar
    Dec 2012
    Mộ Đức__QN
    chuyển sang hợp khác xem!nếu ko đc là dính cặp
    Chuyên Sửa Chữa Smart Phone
    Add: D15/10, Võ Văn Vân, Vĩnh Lộc B, Bình Chánh, TP. HCM
    Tel : 0984.239.639 - 0977.400.296
    Thành viên kỳ cựu thanhchuong1221's Avatar
    Mar 2012
    Bệnh muôn thuở của n200, thay thử thạch anh k đc thì tính cặp là vừa. Đã gặp mấy e.
  1. Trả lời: 5
  2. Trả lời: 5
    Bài viết cuối: 09-01-2013, 15:47
  3. Trả lời: 5
  4. Trả lời: 10
  5. Trả lời: 25
