Xi hỏi Hoàng Thông có bác loại cáp ốp lưng cho Asha 311 không vậy? Giá bao nhiêu tiền. Tnaks
con nay cáp usp phang ngọt mà bác..mua j cho tốn![]()
Chaỵ usb box ATF lỗi:
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000003
ID DWORD 1 : 00000226
ID DWORD 2 : 00010007
ID DWORD 3 : 400C1921
ID DWORD 4 : 03032108
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00001051
3 EM_ASIC_ID 02
ID DWORD 0 : 00001060
4 PUBLIC_ID 12
ID DWORD 0 : 824C0000
ID DWORD 1 : FFFB3C40
ID DWORD 2 : 0A1AB320
ID DWORD 3 : FE381F26
ID DWORD 4 : 0AC25A13
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 2CAC45E2
CRC 1 : 3BC33C8B
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg
Secondary Loader Sent....
MessageID : C1
SubBlocks : 06
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0020 ->
Device ID : 0040 -> Type not in database
Revision ID : 0131
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Type not in database
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Revision ID : 0131
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.6
Flash Descriptor
Device ID : 0040
Revision ID : 0000
Size : 10000000 (256 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
START READING RPL DATA
IMEI: 355193050659394
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
NPC CERTIFICATE INFORMATION (CMT):
IMEI : 355193050659394
PRODUCT CODE : 059F7M4
WLAN ID : 34:C8:03:C9:B5:E7
BLUETOOTH ID : 34:C8:03:C9:19:A7
PUBLIC_ID : 824C0000FFFB3C400A1AB320FE381F260AC25A13
PAPUB_KEYS_HASH: A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355193050659394\3551930506593 94_22805.rpl
PA PUBLIC KEY Request
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
ImagePath: D:\software ini NOKIA\RM-714\
ImageFilename: rm714__05.92.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 00140000
Partition 2
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 04480000
Partition 3
Start Address : 0F080000
Partition 4
Start Address : 0F680000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 00020014000003D000000000000800000001044800000AC000 000000000A000000010F080000006000000000000B00000001 0F680000003000003C
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0xE9 (233)
ERASE Blocks : 0x04 (4)
0 ERASE_AREA_BB5 0x12
Block Length : 0x53 (83)
Device Index : 0x00
0 : 00040000-000403FF
1 : 000C0000-0013FFFF
2 : 00140000-004BFFFF
3 : 004C0000-0073FFFF
4 : 00740000-0173FFFF
5 : 00160000-0017FFFF
6 : 03E40000-0447FFFF
7 : 0F080000-0F67FFFF
8 : 01740000-02ABFFFF
9 : 02AC0000-02F3FFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
3 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 500A120B00030000040000000403FF120B000300000C000000 13FFFF120B00030000140000004BFFFF120B000300004C0000 0073FFFF120B000300007400000173FFFF120B000300001600 000017FFFF120B00030003E400000447FFFF120B0003000F08 00000F67FFFF120B0003000174000002ABFFFF120B00030002 AC000002F3FFFFE7
FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
Successfully Erased...
Total blocks to write : 325
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PAPUBKEYS [A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28]
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : MCUSW1
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : ISA+DYNSW
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : ISA+EXTDRV
ImageFilename: rm714__05.92.ppm_v
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 02F40000-03E3FFFF
ERASE_REQUEST_BB5 : 5001120B00030002F4000003E3FFFF04
Total blocks to write : 101
ImageFilename: rm714__05.92.image_v_059F7M4
StartErase_DCT5...
BlockLength : 0x3F (63)
ERASE Blocks : 0x02 (2)
Device Index : 0x00
0 : 04480000-0F07FFFF
Device Index : 0x00
ERASE_REQUEST_BB5 : 5001120B000300044800000F07FFFF7E
Total blocks to write : 638
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
STATUS_REQUEST_BB5...
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000000
Additional Bad : 00000000
Correctable ECC : 00000000
FlashInfo.RestartMode : 2
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:14
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
SW: V 05.92 10-10-12 RM-714 (c) Nokia
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SUPER_DONGLE_TEST : FAILED
> REPAIR USING FBUS CABLE
> Try "Customized SX4 with SD Repair"
> Then Write PM 1 and 309
SECURITY_CODE : 12345
SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
con máy này lôi ma bác ..
Hãy thử SX4..Sau đó, Viết PM 1 và 309
Customized SX4 with SD Repair thế nào trong box ATF vậy bác?
bạn thử bàng usb chay hộp mx key xem sao.con 311 này chuối lám đấy.không được thì thử SX4 with SD Repair pM 1 và 309 xem sao
bác có thể hướng dẫn giúp mình không vào đâu để sx4......thanks bác.
Đừng dại mà sx4 nhé bạn dòng asha là chỉ có besttoolBB5 là trị được nó thôi !
dòng này k có support fbus mà, lấy best chạy đúng code vẫn done đã tét
