các bac xem giúp cai log giúp em. máy khách mang tới đã bị sửa chữa đương sim khách mang tới bảo không nhận sim em láp sim vào thì báo không đang ký được thẻ sim,không phục vụ.nhưng vào danh bạ sim vẫn tháydanh bạ sim.em thử chạy lại vẫn thấy vậy.xin các báo giúp đỡ
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08747CE
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100CA16
Driver: nmwcdc, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Battery voltage: 4043 mV
Waiting for USB device removal ...
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.44
EBL version: Quantum_Bootloader_10.44_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35906304329970
IMEI_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
LOCK120_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35906304329970_ back.RPL"
Processing file: rm704__03.82.mcusw
Downloading item CODE:rm704__03.82.mcusw_ebl_psi.fls, num block: 4, size: 26 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.360 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.344 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.406 s
Erasing area 0x40280000-0x41B3FFFE ...OK
Programming completed in 31.140 s
Checksum verified (0xE70B)
Processing file: rm704__03.82.ppm_v
Downloading item CUSTackage_v.ppm_ebl_psi.fls, num block: 1, size: 3.97 MB
Erasing area 0x41BC0000-0x41FB874E ...OK
Programming completed in 5.125 s
Checksum verified (0xF4E7)
Processing file: rm704__03.82.image_v_magenta_059C8N6
Downloading item CUSTackage_v_magenta_059C8N6.image. , num block: 1, size: 11.75 MB
Erasing area 0x421C0000-0x43E1FFFE ...OK
Programming completed in 15.078 s
Checksum verified (0x451D)
Total time for flashing process(boot+erase+write) was 7 min 38.875 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C2-00 USB Phonet, PORT_ID: 1071CC47
Verifying communication to device OK.
Phone type: RM-704 (C2-00)
SW version: V 03.82 17-10-11 RM-704 (c) Nokia
Imei plain: 35906304329970-5
Product code: 059C8L1
Battery voltage: 4038 mV, current: 87 mA
Cellular system: GSM
ASIC ID: 0x0000, type: 11
Ppm Id: V
Language Pack:
- not available.
Master code: 4701510361
Camera config: NI00CS0000040C213402, ver: 002.006
Imei net: 35906304329970
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
Market items is empty, please select the correct products path !
Counter: 0/3, 0/10
 LinkBack URL About LinkBacks
			 c2-00 không nhân sim
			 Được post bởi phamtrung
