mình vừa làm con bệnh như bạn vệ sinh sạch rồi dùng hwk chạy lại phần mềm done .bạn tải lại file rm495_7.97 đôi khi file lưu trong máy bị lỗi
em lở chạy ròi chờ xong tính sao đả thank ae đả giúp đở
đả chạy xong máy vẩn y như vậy
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
PARTNERC : Empty
Reading : MDM_KEYS (CMT)
MDM_KEYS : Empty
NPC CERTIFICATE INFORMATION (CMT):
IMEI : 354873047443587
PRODUCT CODE : 059D1F2
BLUETOOTH ID : C8F:7C:52:CC:0E
PUBLIC_ID : 2390000362030356E6D5ED22174BF167450065CF
PAPUB_KEYS_HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\354873047443587\3548730474435 87_60643.rpl
Processing Image File :
C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 6500000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 1178
Entry Point : 0x5057
Page Format : 128K
Maximum Page Size : 0x00004000
Changing MODE : FLASH
Booting Phone via FBUS...
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 23900003
ID DWORD 1 : 62030356
ID DWORD 2 : E6D5ED22
ID DWORD 3 : 174BF167
ID DWORD 4 : 450065CF
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 34
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version 010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MessageID : 03
SubBlocks : 03
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0089 ->
Device ID : 8982 -> NU48F512
Extended/Fixed ID : 0000
Revision ID : 8A31
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : 51
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
Flash Descriptor
Device ID : 8982
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version 010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
PAPUB_KEYS_HASH_REQ_BB5
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
PHONE FIRMWARE VERSION:
V 07.97 13-09-10 RM-495 (c) Nokia
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x36 (54)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x33 (51)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 00000000-000006BF
1 : 000006C0-0001FFFF
2 : 00040000-000BFFFF
3 : 000C0000-0013FFFF
4 : 00140000-0137FFFF
5 : 01380000-0151FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
STATUS_REQUEST_BB5...
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:01:36
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing : rm495__07.97.mcusw
Total blocks to write : 1178
FBUS Cable RX2 PIN Diagnostics
Block Length : 01
BB ASIC Index : 00
INFO: RX2 PIN is OK
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [0C917F11196FDB7378C18EF7260698CA4489DCA0]
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
Block Length : 01
BB ASIC Index : 00
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:52
C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.ppm_v
CMT Type : BB5
Number of Blocks : 494
Entry Point : 0x00BE
Page Format : 128K
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01520000-01DBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:00:40
Processing : rm495__07.97.ppm_v
Total blocks to write : 494
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:18
C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.image_v_red
CMT Type : BB5
Number of Blocks : 824
Entry Point : 0x00D0
Page Format : 128K
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x16 (22)
Block Length : 0x13 (19)
Device Index : 0x00
0 : 01DC0000-0215FFFF
1 : 02160000-03FBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:03:28
Processing : rm495__07.97.image_v_red
Total blocks to write : 824
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:31
Total Flash Write Time (Flashing Only) : 00:01:42
Total Flashing Time (Booting + Erase + Flashing) : 00:07:30
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Basic Phone Information
MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia
IMEI Plain : 354873047443587
IMEI Spare : A354873047443580
IMEI SV : 33548730474435858F
Phone Model: Nokia 5130c-2
Category : Classic Phone
Phone Type : RM-495
Extended Phone Information
Product Serial Number: HMN359931
Product Code : 059D1F2
Module Code : 0204024
Basic Production Code: 0578151
Long Production SN : 0
PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia V
Simlock Information
Unable to read SP Data..
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
FACTORY SET TO : Full Factory Set
FAILED
FACTORY SET TO : User Data
FAILED
FACTORY SET TO : Leave Factory
FAILED
FACTORY SET TO : Service Center
FAILED
FACTORY SET TO : Software Upgrade
FAILED
FACTORY SET TO : Production Tune
FAILED
