mình nhận cây 2700 mất nguồn kẹp dồng mơ nguồn dao động bình thường nhưng tới lúc chuẩn bị rung 1 cái ròi lên nguồn thì kim chở về o.4a và troe ỏi đó luôn ae nao gạp ồi thì giúp với thank
flash e nó cái?? quang log lên xem sao???
cuộc sống thay đổi khi chúng ta thay đổi
flash ròi bạn oi log bus check đây
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 13D00114
ID DWORD 1 : BF8E0356
ID DWORD 2 : E8C87ABD
ID DWORD 3 : 7F252D28
ID DWORD 4 : 021FE143
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum E2
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version 010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MessageID : 03
SubBlocks : 03
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 2400 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 8A31
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : D5
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :00EC DevID :2400 ExtID :0000 RevID :8A31
Flash Descriptor
Device ID : 2400
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version 010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
PAPUB_KEYS_HASH_REQ_BB5
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
3EA22A1DDA660002E56108DB5072A10F8709443F
PHONE FIRMWARE VERSION:
V 09.98 06-09-10 RM-561 (c) Nokia
Scanning Simlock Applet Type...
OK
PA_SL3 Applet detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FACTORY SET TO : Full Factory Set
FAILED
FACTORY SET TO : User Data
FAILED
FACTORY SET TO : Leave Factory
FAILED
FACTORY SET TO : Service Center
FAILED
FACTORY SET TO : Software Upgrade
FAILED
FACTORY SET TO : Production Tune
FAILED
rồi xong mất simlock ....
làm thế này hên xui khò nóng con flash rồi chec info ok thì backup để thay flash
tai sao ma mất sim lock vậy bạn do mình chạy sai hay do máy lỏi trước
thông thường do con flash nó khìn khìn bi thôi . và làm theo cách trên cũng hên dc nhìu e lắm![]()
lắc lại con flash nếu lên là nó lên luôn đã gặp nhiều còn không thì backup lại rồi thay mới
gmail: Doanhtruong_090
Agribank STK:3503205057189
NGUYỄN VĂN HẢI ,Đ/C châu thành an giang
yahoo thanhhaimobile46
chủ tk nguyễn văn hải 4221515164695134 ngân hàng sacombank
đt ; 0972393493 0968144546
ĐỜI LÀ BỄ KHỔ
YÊU LÀ CÁM DỔ
KO YÊU THÌ LỔ
CÒN YÊU THÌ KHỔ
THÀ CHỊU KHỔ CHỨ KO CHỊU LỔ
lag roi vẩn not ok roi
với lại khong biết do hôp atf mình lỏi hây sao ma hôm rài chạy máy cay 2700 với 2730 dêu bị ko factory full duoc với lại nạp pm đều bị contac sevics
