đóng lại lên nguồn rùi,nhưng ko thu dk sóng
ae vào xem lại mình cái
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087FD0B
Using device: HTI, FW ver: 00.50, SN: 010106DE
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
RPL backup already exist (C:\mobileEx\3.5\data\backup\BB5_35376204120196_BA CK.rpl).
Processing MCU file: rm578__10.47.mcusw
[BB5,BB5 ALGORITHM] size: 21.65 MB
Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101023000 [RAP3G ver: PA 3.0]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0E50021778C6005693C20178B45B618B246159B5
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 23.25 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-0155FFFF]
CMT FLASH,NOR area [01560000-0175FFFF]
erased in 1 min 45.891 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 8669C775 [RAP Certificate 215 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 12.969 s
Processing PPM file: rm578__10.47.ppm_v
[BB5,BB5 ALGORITHM] size: 6.78 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 8.62 MB
CMT FLASH,NOR area [01760000-01FFFFFF]
erased in 32.484 s
NOR: OK
NOR: OK
Programming completed in 23.343 s
Processing CNT file: rm578__10.47.image_v_red_v2
[BB5,BB5 ALGORITHM] page size: 128 K size: 15.64 MB
NOR page size in the phone is 128 K.
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 31.75 MB
CMT FLASH,NOR area [02000000-0245FFFF]
CMT FLASH,NOR area [02460000-03FBFFFF]
erased in 3 min 34.719 s
NOR: OK
Converting UCP blocks to 128 K.
NOR: OK
Programming completed in 53.468 s
Total time for flashing process(boot+erase+write) was 8 min 55.641 s
After Flash Processing ...
Reseting Factory Values OK.
Phone type: RM-578 (Nokia 2730 classic)
SW version: V 10.47 27-08-10 RM-578 (c) Nokia
Imei plain: 35376204120196-1
Product code: 0585566
Battery voltage: 4627 mV, current: 29 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NI00IIIIRR030102F201, ver: 006.006
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353762041201961
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
xin chúc mừng đã có lúa![]()
nó ko có sóng nè a ơi,,ở chổ này có lổi gì ko ...SIMLOCK seems to be valid
SIMLOCK_TEST passed
mất sóng thu a
