nhận cây asha 305 bật nguon rung xong hiển chử nokia trong giay lat là tắt
mình đang mang qua ATF flash thì em nó chạy hết cả 3 file nhung ko đông bộ factory thi khong dc
cho thuc lắc con fash và cpu chung y chang ko có gì tiến triển :
đây là tinh dang logo em nó:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\359059048272689\3590590482726 89_PMM_PROT_60596F20.bin
Security Code: 12345
Data Sections : 04
Current File : rm766__07.42.mcusw
Compile Name: rm766__07.42.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 29117832 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 1369
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 73CD
Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4011FFFE
Start Erasing...
Block Erase Done...
Data Size: 786432 bytes
Data Checksum: 3B38
Processing Section 04
FIRMWARE Erase Block: 0x40120000~0x41BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 28065792 bytes
Data Checksum: 1302
Processing Section 05
FIRMWARE Erase Block: 0x43EE0000~0x43EFFFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File : rm766__07.42.ppm_v
Compile Name: package_v.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 8124656 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41C00000~0x423FFFFE
Start Erasing...
Block Erase Done...
Data Size: 8121312 bytes
Data Checksum: 86C3
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File : rm766__07.42.image_v_059L0H4
Compile Name: package_v_059L0H4.image.fls
Image Type : CONTENT Package
Data Size : 14552336 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42400000~0x43EDFFFE
Start Erasing...
Block Erase Done...
Data Size: 14548992 bytes
Data Checksum: 5CAC
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43F00000~0x43F7FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:03:59
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)![]()
TuanKiet3336@yahoo.com
