như tieu đề e flash nó báo lỗi như này ạ
Number of Image Files: 1
Processing Image File :
A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin
CMT Type : MAEMO/MEEGO
C:\AdvanceBox Turbo Flasher\Logs\flasher.exe
-F A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin
C:\Program Files\Nokia\Phoenix\Products\RM-696\
BB5 MEEGO / HARMATTAN FLASHER
1. Turn OFF Phone and wait 10 Seconds...
2. Connect the USB Cable to the PHONE Micro USB Port
3. Connect the USB Cable to the PC USB Port
TIPS & INFORMATION:
1. To Turn OFF the Phone, PRESS and HOLD the POWER
button for at least 10 Seconds...
2. Battery Charging will still work on "DEAD" Phones.
3. Factory Reset will make Flashing 15 minutes longer
and it will Totally Erase the User Data and Remove
the Phone Lock + Security Code as well...
4. Skip ADL Chk will Cold Flash the Device.
Waiting For Phone on USB PORT/s...
REQUIRED MODE: BOOTROM MODE
Sending PRIMARY-BOOT: SUCCESSFUL!
Sending SECONDARY-BOOT: SUCCESSFUL!
SECURE USER DATA ERASING IN PROGRESS
Secure Data Erasing takes about 15 MINUTES...
DO NOT DISCONNECT THE PHONE!!! JUST WAIT...
Estimated time to Finish Erasing: 16:07:17 (24-h Time Format)
Battery Voltage Test: PASSED
Ready to Flash Images to Device...
Processing Image: cert-sw
ERROR: MEEGO Device Flashing Failed!
Firmware Version Downgrade NOT ALLOWED
Please use a HIGHER Firmware Version...
