lúc đầu máy mất sóng , mở ra thấy bo còn rất đẹp , nên mình flash thử , máy có sóng nhưng gọi bị lổi kết nối , mạng bận , mình write pm , repair SD , cũng y như cũ , log check của nó đây , Mong AE giúp
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000232
EM1 ID: 00000352
PUBLIC ID: 0DE0010753890154469AFF5F392CB9551C4FDBF7
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 0001 002F - 0000 0121 [AMD S29NS256N,256 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 2F36DDC4990FD844712A61A80C033211BD9602E3
TransmissionMode: DDR&TX2
Selected firmware certificate matched.
Original Imei: 35972700436948
Original Product code: 0536490
Bluetooth ID: 0017B0B46AB7
SIMLOCK PA identifier:
[0] PA_SL
Phone type: RM-145 (Nokia 6233)
SW version: V 05.60 14-09-07 RM-145 (c) Nokia
Imei plain: 35972700436948-9
Battery voltage: 4892 mV, current: 78 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
Imei net: 359727004369489
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
mình thấy nó thiếu dòng SECURITY_TEST .......
mình Recover CERT thì báo lổi như vầy
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000352
ASIC MODE ID: 00
Begin Certificate Request ...
[InternalErrorFault] CERT [0536490] data not available for this phone (case id=0xCE01)
MONG AE GIÚP ....
