máy bị hiện tượng nhiều luc tự khởi động lại em đã flast tháy nó có báo lỗi này nhưng mọi chức năng sóng sánh bình thường.giúp em cách xử lý em có atfbox.hay con này bị phần cứng ạ
Processing Image File :
rm470__13.21.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 230
Entry Point: 0x0249
Page Format : -1
MAX PAGE : 0x00020000
[]: Found 1 active devices.
[Nokia 6700 classic USB Phonet]: Opening Connection
[Nokia 6700 classic USB Phonet]: Port opened OK!
SW: V 13.21 12-01-11 RM-470 (c) Nokia
IMEI: 355364045897767
CONFIG KEY : 8000000000000002
PROVIDER KEY : 2440700000000000
NETWORK NAME : Nokia Default;Finland
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE : Not Locked
START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
FULL PM Backup Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355364045897767\USB_FULL_BACK UP_V 13.21 12-01-11 RM-470 (c) Nokia_355364045897767_Not Locked_43652.pm
Reading Battery Value : 3703 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000003
ID DWORD 1 : 00000226
ID DWORD 2 : 00010007
ID DWORD 3 : 600C1921
ID DWORD 4 : 02011104
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000C35
3 EM_ASIC_ID 02
ID DWORD 0 : 00000C30
4 PUBLIC_ID 12
ID DWORD 0 : 0FA00013
ID DWORD 1 : BCD00344
ID DWORD 2 : BC019620
ID DWORD 3 : 6AC1C995
ID DWORD 4 : 7903A39C
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 25 B9 77 A0 55 BE 9B 5D EC 0C 38 A2 A2 79 C6 95
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 3E273BF6
CRC 1 : 37BE26FA
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
Secondary Loader Sent....
MessageID : C1
SubBlocks : 05
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Type not in database
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 0098 ->
Device ID : 0040 -> Type not in database
Revision ID : 0031
Flash Descriptor
Device ID : 0040
Revision ID : 0000
Size : 10000000 (256 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
START READING RPL DATA
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
NPC CERTIFICATE INFORMATION (CMT):
IMEI : 355364045897767
PRODUCT CODE : 0577784
BLUETOOTH ID : 9C:4A:7B:FC:7F:F8
PUBLIC_ID : 0FA00013BCD00344BC0196206AC1C9957903A39C
PAPUB_KEYS_HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355364045897767\3553640458977 67_43659.rpl
PA PUBLIC KEY Request
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Reading : ISA-USER... OK!
PHONE FIRMWARE VERSION:
V 13.10 16-06-10 RM-470 (c) Nokia
ImagePath: D:\software ini NOKIA\RM-470\
ImageFilename: rm470__13.21.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 000A0000
Partition 2
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 02FC0000
Partition 3
Start Address : 0F2C0000
Partition 4
Start Address : 0F8C0000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 0002000A000002860000000000080000000102FC00000C3000 000000000A000000010F2C0000006000000000000B00000001 0F8C0000001800003D
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0xD9 (217)
ERASE Blocks : 0x04 (4)
0 ERASE_AREA_BB5 0x12
Block Length : 0x43 (67)
Device Index : 0x00
0 : 00020000-000203FF
1 : 00060000-0009FFFF
2 : 000A0000-0041FFFF
3 : 00420000-0069FFFF
4 : 006A0000-01F1FFFF
5 : 02900000-02FBFFFF
6 : 0F2C0000-0F8BFFFF
7 : 00000000-0001FFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
3 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5008120B00030000020000000203FF120B0003000006000000 09FFFF120B000300000A00000041FFFF120B00030000420000 0069FFFF120B000300006A000001F1FFFF120B000300029000 0002FBFFFF120B0003000F2C00000F8BFFFF120B0003000000 00000001FFFF39
FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
Successfully Erased...
Total blocks to write : 230
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6]
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : LDSP
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : ISA+DYNSW
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
STATUS_REQUEST_BB5...
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000000
Additional Bad : 00000000
Correctable ECC : 00000000
FlashInfo.RestartMode : 1
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:04
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
SIMLOCK TABLE :
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SUPER_DONGLE_TEST : FAILED
> REPAIR USING FBUS CABLE
> Try "Customized SX4 with SD Repair"
> Then Write PM 1 and 309
SECURITY_CODE : 12345
SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
