Kết quả 11 tới 14 của 14
    Thành viên tích cực sonfa139's Avatar
    May 2011
    AE ai làm được vào giúp mình tí
    May 2011
    Bush check bằng Mx Box thì chỉ đến đây thôi
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0855593
    Using device: HTI, FW ver: 00.50, SN: 010151FF
    Connection status: IUSB3XHC:IUSB3HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
    Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
    CMT Data :
    SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
    EM0 ID: 00000C35
    EM1 ID: 00000C30
    PUBLIC ID: 14B00209A79C0344823613195909B82117E7DEA0
    ASIC MODE ID: 00
    ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
    ROM ID: E693EF0DAC22615B
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
    Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569
    FUR: Adding Asic CMT as client OK
    CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
    Selected firmware certificate matched.
    Original Imei: 35379204627726
    Original Product code: 0593574
    Bluetooth ID: E0A67021CEAE
    SIMLOCK PA identifier:
    [0] PA_SIMLOC30
    Thành viên tích cực dongdt's Avatar
    Jan 2013
    xóa last đi lấy bétool kết hợp với atf cây được cây ko bác ak
    yahoo : diemhentinhyeu469
    dt:0944788081
    Moderator tranduy959's Avatar
    Apr 2014
    xóa full rồi nạp lại xem
