APE blocks present in flash file but no APE mcu detected in phone. Aborting!
đây là lỗi nè bạn! nó bảo là ko có APE của CPU đó,nghĩa là thiếu APE rồi, nếu có hình thì câu lại đi. nếu ko có thì xem hình của các pác đã post ở ngay trên ý.
good luck!
good luck!
còn đây là khi mình INF ra
JAF version 1.98.62
Detected PKEY: 9002D7B4
Card life counter: 64.11%
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101012200
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 131000131ECB4F5144B922C63A2E2363E61D9EF5
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 00330001 <=> SPANSION -> Type not in database
CMT Loader Ready
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05wk07v48.2
04-10-07
RM-180
(c) Nokia.
HW version: 7001
PCI version:
RFIC version: 150a160f
DSP version: rolf_espresso_05wk07v29p1
Retu version: 32
Tahvo version: 53
Production serial number: MRD855093
Product code: 0531541
Module code:
Basic production code: 0530940
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 355721025850449
IMEI spare to net: 3A 55 27 01 52 58 40 04
IMEI SV to net: 33 55 27 01 52 58 40 04 F9
LOCK STATUS:
CONFIG KEY: 0000000000000000
Provider: AT&T;U.S.A. (3650)
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini
Setting local mode...
Reading product code...
Product Code: 0531541
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\
Scanning for ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50741401.C0
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50741401.V12
Languages in ppm: English,Trad Chinise,Indian
Done!
mình đã làm như thế này rui mà vẫn không đc
còn đây là bị trắng màn hình . mình kiểm tra thì thấy ic kính bị đứt 3 chân như trong ảnh . bạn nào có cách j xin chỉ jup : thank you
bạn xài jar bản crack hay pkey,
khoaj_chjen (27-11-2009)
con IC khiển mà hình lỡ gỡ ra bị đứt chân rồi thì bạn gỡ nó ra ngoài luôn đi
câu lại áp Ape sau đó test lại lần nữa xem có chạm không.
trắng treo thì bạn làm theo mấy huynh o trên là ok nếu máy rớt thì kiểm tra omas thôi
