cho cable bụng vào dí cho nó 1 phát lụm xiền
máy bị mã bão vệ chạy usb tới già cũng ko dc
Hoàng Tuấn mobile
gò dầu/ Tây Ninh
thanhanh822000 (08-09-2008)
Chắc không anh? Nếu tôi chạy oki thì sao nhỉ?
@thanhanh822, :
1- máy có áp Vbat
2-Khi cắm cáp là đã có mass rồi
3-Phải cấp cho chân BSI để màn hình hiện local mode thì mới chạy oki,
Khi máy vào local mode thì bạn kg cần phải nạp lại phần mềm mà vẫn mở mã bảo vệ oki. Đã tet 6233, 5200..
version 1.98.58
Detected PKEY: 90010A5A
Card life counter: 98.65%
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
Detected P-KEY: 90010A5A
Init usb communication...
Found
Init usb flashing...
Reading flashid... 128k flash detected.
CMT: 2D7E0001 <=> SPANSION -> Type not in database
APE: 00000000 <=> Flash -> not detected
Done!
Searching for phone...Detected P-KEY: 90010A5A
Found
MCU SW version: V 05.43
30-03-07
RM-145
(c) Nokia
HW version: 2000
PCI version:
RFIC version: 17211721
DSP version: pb05wk46v49
LCD version: SEIKO
PPM version: V 05.43
30-03-07
RM123_145_-
(c) Nokia
V
Retu version: 32
Tahvo version: 52
Production serial number: CLD188812
Product code: 0536490
Module code:
Basic production code: 0528588
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 359727002579840
IMEI spare to net: 3A 95 27 07 20 75 89 04
IMEI SV to net: 33 95 27 07 20 75 89 04 F6
LOCK STATUS:
CONFIG KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Loading INI list...
Reading product code...
Product Code: 0536490
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-145\
Checking path: C:\Program Files\Nokia\Phoenix\Products\Products\RM-145\
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Done!
Done!
Done!
Setting test mode...
Setting FULL FACTORY...
Operation took 0 minutes 0 seconds...
Done!
HẠNH NGUYÊN MOBILE.
sybenlove (09-09-2008)
có nghĩa là phone vào dc chế độ local thì máy mình mới nhận diver phone đúng ko anh , tại vì máy bị mã bão vệ bật nguồn lên ko thể nào kết nối cáp dc
Hoàng Tuấn mobile
gò dầu/ Tây Ninh
chỉ cần Pkey+USB máy BB5 chạy flash và mở mã bảo vệ ok bạn chỉ cần tích dấu vào dear USB là được (lưu ý là nhớ cài driver cho máy cần chạy)
