Kết quả 11 tới 18 của 18
    V.I.P TânĐạiDương's Avatar
    Jan 2007
    59A QL 13-HBP-Thủ Đức-TP.HCM
    Trích Được post bởi toanphong Xem bài viết
    1ST BOOT : C0,0C [Rm-84] [2.0.8.0]
    OMAP ID : 17100701
    OMAP MODE : 00
    OMAP PBID : E82E9DC50CD9A689AA0249EBCB33872A05586C53
    OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B
    OMAP ROID : AB5E4ADB27A06946
    RAPx ID : 000000010000022600010006000C192101002200
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx PBID : 0CD0011823165651A4747666B399D4DFC97B1897
    RAPx MODE : 00
    RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14
    RAPx ROID : F28A211FCEA7B19D
    CMT 1ST Boot OK
    CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0
    CMT FLID0 : 00EC2250-00000121, Sam K8S6415ETB
    CMT FLCNT : 00000000000000000000000000000000000000
    CMT MCID0 : FFFF0000-00000000
    CMT 2ND Boot OK
    CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5
    CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
    CMT VPP : Internal
    DUAL LINE : False
    CMT ALG Boot OK
    IMAGE : RM84_3054623.C0
    CMT NOR Erase Area: 0x00000000-0052A891
    CMT NOR Erase Area: 0x006A0000-006BFFFF
    CMT NOR Erase Area: 0x006DF000-006EFFFF
    CMT NOR Erase Area: 0x00700000-007EFFFF
    CMT FLASH ERASE OK, Time: 00:43
    CMT FLASH WRITE OK, Time: 00:30
    OMAP ID : 17100701
    OMAP MODE : 00
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx MODE : 00
    CMT 1ST Boot OK
    CMT 2ND Boot OK
    CMT VPP : Internal
    DUAL LINE : False
    CMT ALG Boot OK
    APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0
    APE FLID0 : 00980036-00A500C0, Tos NAND-512
    APE RQALG : OMAP1610 GBBM-1.8.1 ALG
    APE FLCNT : 01010000020000000600000000000000000000
    APE 2ND Boot OK
    APE ALG0 : h3_sam_nand_gbbm.fg, Ver: 1.33.0
    APE VPP : Internal
    APE KSIG1 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
    DUAL LINE : False
    APE ALG Boot OK
    APE NAND Erase Area: 0x00000000-0000FFFF
    APE NAND Erase Area: 0x00010000-0001FFFF
    APE NAND Erase Area: 0x00020000-000203FF
    APE NAND Erase Area: 0x00050000-03ECFFFF
    APE FLASH ERASE OK, Time: 00:05
    APE FLASH WRITE OK, Time: 02:30
    OMAP ID : 17100701
    OMAP MODE : 00
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx MODE : 00
    CMT 1ST Boot OK
    CMT 2ND Boot OK
    CMT VPP : Internal
    DUAL LINE : False
    CMT ALG Boot OK
    APE 2ND Boot OK
    APE VPP : Internal
    DUAL LINE : False
    APE ALG Boot OK
    IMAGE : RM84_3054623.V01
    APE NAND Erase Area: 0x01DE0000-028FFFFF
    APE NAND Erase Area: 0x02900000-03ECFFFF
    PPM FLASH ERASE OK, Time: 00:02
    PPM FLASH WRITE OK, Time: 01:00
    Flashing Completed, Rebooting Mobile
    * Nếu Nạp MCU+PPM xong bạn check info rồi đánh dấu hết các mục Phía dưới UI Options rồi bấm UI Settings rồi thử lại coi có đc kô .
    * Nếu kô đc bạn nên Backup PM full và RPL rồi lưu vào nơi an toàn trước rồi tạo chân mới đóng lại 2con IC nguồn (RETU và TAHVO ) Thử có đc kô . vì máy bạn vô nc nên có khả năng bị ẩm nc trong tất cả các con IC kô đổ keo !
    Nhận Bẻ Khóa -Sữa ĐTDĐ Lấy Liền-Nạp Tiếng Việt Sửa Lỗi,Nâng Cấp Phần mềm-389/1A-QL 13-Hiệp Bình Phước-Q.Thủ Đức-TP.HCM-0909445774
    V.I.P NguyênChương-XM's Avatar
    Jun 2008
    103.PHT.TP.VŨNG TÀU
    cho qua jaf flash lại , không hết thì write pm full + unlock xem có hết không
    CÂY THẲNG LÊN NHỜ UỐN , NGƯỜI KHÔN LÊN NHỜ NGƯỜI
    Thành viên tích cực ht_mobile's Avatar
    Dec 2007
    MÁy vô nước thì vệsinh thật kĩ, trường hợp của bạn mình đã gặp bạn đóng lại con Combo memory xem sao nha
    Thành viên mới klnamcanh's Avatar
    Nov 2008
    Ban thu xem ime ?????????????? Hay ko.neu ime ?????????????? Ban nen di gui file di 350 day.minh bi roi gui file ok
    cảnh cáo lần đầu!Tv có dấu không spam nha!
    V.I.P minhphuc's Avatar
    Apr 2006
    Trích Được post bởi klnamcanh Xem bài viết
    nói tầm bậy không ah bb5 chứ đâu phải dct4 đâu!
    V.I.P sybenlove's Avatar
    Oct 2007
    tầm bậy mà còn tiếng việt không dấu.
    bb5 nếu banh ime là thành 1 cái sãnh áh.
    V.I.P DinhKha™'s Avatar
    Jul 2008
    Kiên Giang
    làm chân con nguồn lại đi bạn
    Thành viên mới ktv_dienthoai1's Avatar
    Oct 2008
    cái bệnh này bạn chỉ cân fotmas nhiều lần là đươc thôi bạn ơi
