Kết quả 1 tới 8 của 8
    Thành viên chính thức boykiengiang_kiengiang's Avatar
    Aug 2007
    Red face write pm báo lỗi sx4 auth
    Writing PM...
    Field: 1, Record: 0, Len: 114 -> Error: Need SX4 auth..
    Field: 1, Record: 2, Len: 98 -> Error: Need SX4 auth..
    Field: 1, Record: 4, Len: 110 -> Error: Need SX4 auth..
    Field: 1, Record: 6, Len: 98 -> Error: Need SX4 auth..
    Field: 1, Record: 8, Len: 110 -> Error: Need SX4 auth..
    Field: 1, Record: 13, Len: 98 -> Error: Need SX4 auth..
    Field: 1, Record: 16, Len: 98 -> Error: Need SX4 auth..
    Field: 1, Record: 18, Len: 98 -> Error: Need SX4 auth..
    Field: 1, Record: 20, Len: 98 -> Error: Need SX4 auth..
    Field: 1, Record: 22, Len: 16 -> Error: Need SX4 auth..
    Field: 1, Record: 23, Len: 4 -> Error: Need SX4 auth..
    Field: 1, Record: 24, Len: 84 -> Error: Need SX4 auth..
    Field: 1, Record: 25, Len: 4 -> Error: Need SX4 auth..
    Field: 1, Record: 29, Len: 6 -> Error: Need SX4 auth..
    Field: 1, Record: 33, Len: 36 -> Error: Need SX4 auth..
    Field: 1, Record: 34, Len: 80 -> Error: Need SX4 auth..
    Field: 1, Record: 44, Len: 182 -> Error: Need SX4 auth..
    Field: 2, Record: 0, Len: 436 -> OK
    Field: 3, Record: 0, Len: 3 -> OK
    Field: 4, Record: 0, Len: 1 -> OK
    Field: 4, Record: 1, Len: 60 -> OK
    Field: 4, Record: 2, Len: 44 -> OK
    Field: 4, Record: 3, Len: 10 -> OK
    Field: 4, Record: 4, Len: 8 -> OK
    Field: 4, Record: 5, Len: 8 -> OK
    Field: 4, Record: 9, Len: 5 -> OK
    Field: 4, Record: 18, Len: 80 -> OK
    Field: 4, Record: 19, Len: 4 -> OK
    Field: 8, Record: 0, Len: 12 -> OK
    Field: 8, Record: 1, Len: 12 -> OK
    Field: 8, Record: 2, Len: 128 -> OK
    Field: 8, Record: 3, Len: 128 -> OK
    anh nao chĩ em kết nối nhé em kết nối nó bao lổi hoài ah báo như vậy nè
    Checking for local SX card...
    Trying to use SX4 server...
    Server say: Hello!
    Login...
    Detected P-KEY: 90014449
    Server say: Login OK, you are number 1 in the queue, you must wait aprox. 0 seconds...
    Connecting to phone...
    Error receiving data from server step2.
    thanks trước nhé
    yahoo; hoangtam_oht
    V.I.P tuanmb's Avatar
    Feb 2008
    - bạn cho hỏi thêm thông tin máy bạn bị gì mà write sx4, để kiểm tra có ok không thì bạn lấy một cây máy good write sx4 thử xem sao, có một số máy bị data crup, thì mình không thể sx4 được nhe bạn
    Thành viên chính thức dat_coca2001's Avatar
    Jul 2007
    Trích Được post bởi boykiengiang_kiengiang Xem bài viết
    Writing PM...
    Server say: Hello!
    Login...
    thanks trước nhé
    làm vài lần nữa đi bạn bữa truớc mình làm tới 4,5 lần mới được đó lỗi server thôi
    LOVE IS ALL
  4. ( dat_coca2001 ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    dduongnokia (19-12-2008), hhoangtumobile (19-12-2008)
    Aug 2007
    máy mình bị lổi pm rui ......... người ta điện lại tắt khỏi động lại nguồn..... mình điện cho người ta thì ko sao hết vẫn bình thường ........ mình đã làm đi làm lai 2 ba lần rùi mà ko đc ........... hầu như máy nào em củng kết nối nó báo như vây hết ....... mấy anh còn cách nào ko chĩ em với ....huhuhu
    yahoo; hoangtam_oht
    Thành viên chính thức HP Mobile's Avatar
    Dec 2008
    My Home
    Wink
    Server của JAF hiện tại không vào được SX4, mang qua HWK viết cho nhanh và lụm lúa!
    Ở đời có 5 cái ng u:
    Làm mai - lãnh nợ - gác cu - cầm chầu - cái ng u cuối cùng là ngồi câu cá.
    Thành viên mới Đình Hiếu's Avatar
    Oct 2006
    Không thấy báo connecting phone done thì làm sao mà sx4?
    Endless Love
  8. #7
    Thành viên mới vinhcala's Avatar
    Dec 2007
    Jaf đôi khi connect SX4 và update pkey không được có thể do server Jaf hoặc version Jaf quá thấp.
    PS: bạn muốn write pm full bằng jaf thì phải connet SX4 thui.
  9. #8
    Aug 2007
    uh . cám ơn mấy anh nhiều nhé
    yahoo; hoangtam_oht
  1. hwk sx auth
    By quocchuong566 in forum HWK
    Bài viết cuối: 29-09-2009, 15:43
  2. J.A.F Không SX4 AUTH được hepl
    By nghiamobile2007 in forum J.A.F
    Bài viết cuối: 30-06-2009, 10:26
  3. hỏi về vấn đề kết nối SX4 AUTH
    By dat_coca2001 in forum BB5
    Bài viết cuối: 14-12-2008, 11:14
