anh em mở mạng nào mở mạng con này rùi xin chia sẻ dùm thanks anh đây là LOG của nó
Powering the phone...
Reading...
MCU SW version: V 05.92
14-03-08
RM-359
(c) Nokia
HW version: 1901
PCI version:
RFIC version: 17141715
DSP version: ICPR71_08w03_3_1
LCD version: SHARP
PPM version: V 05.92
14-03-08
RM-358
(c) Nokia
NTM
BT MCM version: 2222-143
Retu version: 15
Tahvo version: 22
Content Pack version: Content: n_tmobusa_red_v2_June13th08
V 05.92
14-03-08
RM-358
(c) Nokia
Production serial number: CEK107776
Product code: 0557826
Module code: 0203577
Basic production code: 0553722
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 352941021256440
IMEI spare to net: 3A 25 49 01 12 52 46 04
IMEI SV to net: 33 25 49 01 12 52 46 34 F5
LOCK STATUS:
CONFIG KEY: 8000000000000000
PROVIDER KEY: 3102000000000000
Provider: T-Mobile;U.S.A.
Block 1:
Lock 1: CLOSED -> Lock Data: 310160
Block 2:
Lock 1: CLOSED -> Lock Data: 310200
Block 3:
Lock 1: CLOSED -> Lock Data: 310210
Block 4:
Lock 1: CLOSED -> Lock Data: 310220
Block 5:
Lock 1: CLOSED -> Lock Data: 310230
Block 6:
Lock 1: CLOSED -> Lock Data: 310240
Block 7:
Lock 1: CLOSED -> Lock Data: 310250
Block 8:
Lock 1: CLOSED -> Lock Data: 310260
Block 9:
Lock 1: CLOSED -> Lock Data: 310270
Block 10:
Lock 1: CLOSED -> Lock Data: 310310
Block 11:
Lock 1: CLOSED -> Lock Data: 310580
Block 12:
Lock 1: CLOSED -> Lock Data: 310660
Block 13:
Lock 1: CLOSED -> Lock Data: 310800
Block 14:
Lock 1: CLOSED -> Lock Data: 310490
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-359.ini
Setting local mode...
Reading product code...
Product Code: 0557826
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-359\
Checking path: \Products\RM-359\
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Done!
