em vào camera thì bi lỗi và báo :"unexpected error occurred. power pff the device and restart"
vào thẻ nhớ thì lại báo"memory card corrupted" fomat thẻ cũng không được. em không cắm thẻ nhớ vào cung báo vậy.
chạy lại phần mềm thì bị lỗi
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101002200
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 0F00010D8E225951F16E6C3BAAE7B86D6B9E6DA5
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
CMT Loader Ready
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05wk07v48.1
28-08-07
RM-84
(c) Nokia.
HW version: 7002
PCI version:
RFIC version: 150a160f
DSP version: rolf_05wk07v29p1
Retu version: 32
Tahvo version: 53
Production serial number: CTD205094
Product code: 0539276
Module code:
Basic production code: 0536420
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356294010458577
IMEI spare to net: 3A 65 92 04 01 54 58 07
IMEI SV to net: 33 65 92 04 01 54 58 17 F2
LOCK STATUS:
CONFIG KEY: 0000000000000000
Provider: AT&T;U.S.A. (3650)
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini
Setting local mode...
Reading product code...
Product Code: 0539276
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\
Scanning for ini files...
INI file 0539276.ini is missing. Continue searching for second ini type...
Checking path: \Products\RM-84\
No ini files found...
APE Variant file: ?
Done!
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50717301.C0
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\V150717301_RM84_VFrd.VQ8
APE Variant file: ?
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\35629401045857_CRT_backup _81233.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\356294010458577_CRT_backu p_82233.pm
Done!
Backup LCK OK!
Manual mode selected, version can't be checked!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Operation took 0 minutes 4 seconds...
Sending CNF Data...
APE blocks present in flash file but no APE mcu detected in phone. Aborting!
máy gọi nghe bình thường. mong các anh chỉ bảo.
