Kết quả 1 tới 9 của 9
    Thành viên tích cực dungxi's Avatar
    Feb 2008
    Mặc định xem dùm em cái log 6500s
    JAF version 1.98.62
    Detected PKEY: 90019A5A
    Card life counter: 71.67%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-240\
    Checking path: \Products\RM-240\
    No ini files found...
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__08.30.mcusw
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__08.30.ppm_v
    Languages in ppm: English,Chinese Simpl,Chinese T,Vietnamese
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__08.30_ism_015.image_v
    Backing up CRT data...
    Setting FLASH MODE
    FAST PHONE detected!
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 73656C69 <=> Flash ID not in database
    CMT Flash Data: NOT AVAILABLE
    Error finding cmd loader...
    Error loading cmt loader...
    Failed to backup CRT...
    Backing up SIMLOCK data...
    Setting local mode...
    Failed! Aborting!
    Failed to backup LCK...
    Manual mode selected, version can't be checked!
    PPM: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__08.30.ppm_v
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101003000
    Asic Mode ID: 00
    Asic EM ID: 00000B22
    Asic Public ID: 16F0000657604E502B4BE4FEB6563AC9A60C7C37
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 273F6D55DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    CMT Boot Ready
    Thành viên tích cực shockcuteboy's Avatar
    Apr 2009
    Thiên Đàng
    banh IMEI rùi phải ko bạn?
    Khôi Mobile: Chuyên làm tất cả các dịch vụ liên quan đến DTDD. Đặc biệt: Biến máy sống thành máy chết trong 5s. Đ/C: Gò Đen_Long An:D
    V.I.P Mr_Diep's Avatar
    Nov 2007
    Bạn kiểm tra lại cable , nếu cable ok thì vấn đề ở cặp ic chồng rồi đo ( CPU & flash).
    p/s: Tập đục đẻo đi
    Thành viên mới minhduong82's Avatar
    cái này BOX báo lôi ko tìm thấy bộ nhớ Bạn kiẻm tra con flash nhé chúc thành công.
    Sep 2008
    lỗi này nằm ở cap74 (cpu & flash ) rùi
    Thành viên tích cực tranhoimobile's Avatar
    Nov 2007
    bác thử flat lại qua usb xem .nếu vẫn not ok thì đục đẽo flat dần đi thôi
    Feb 2008
    máy tình trạng ban đầu là chạm mất nguồn.em đã gỡ con công suất ra hết chạm rồi nhưng ko lên nguồn em đưa vào box chesh thì nó báo như vậy đó
    Thành viên mới thaonguyenmobile's Avatar
    Aug 2006
    lỗi nó nằm ở đây nè bạn:
    kiểm tra lại cpu và flash.
    729 TRƯƠNG ĐỊNH-HOÀNG MAI-HN SỬA CHỮA,UNLOCK,MỞ MẠNG,NẠP PHẦN MỀM...CHUYÊN NGHIỆP.ĐT:0944628899
    Apr 2009
    Thiên Đàng
    uh có vẻ bị CPU hoặc flash rùi
  1. nhờ mọi người xem dùm log 6500s
    By phamcuongmobile_1990 in forum BB5
    Bài viết cuối: 09-07-2012, 18:18
  2. Anh em xem dùm log 6500s
    By chithang8xx in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 20-09-2009, 13:28
  3. anh em xem dùm em cái log 6500s
    Trả lời: 22
    Bài viết cuối: 30-08-2009, 21:43
  4. xem dùm log 6500s
    By nhuttruongdt in forum BB5
    Bài viết cuối: 01-07-2009, 14:14
  5. Anh em xem dùm log 6500s
    By namkhanh2828 in forum BB5
    Bài viết cuối: 14-02-2009, 18:12
