Kết quả 1 tới 10 của 10
    Thành viên chính thức lenamvan_tn's Avatar
    Jan 2008
    Mặc định 6300 cần giúp gấp
    6300 khởi động máy lên chữ NOKIA, rồi chớp chớp mất nguồn luôn, em chạy ct bằng JAF USB, chạy hoài nó cứ báo lỗi gì em ko hiểu, mong giúp đở
    JAF version 1.98.61
    Detected PKEY: 9001DF77
    Card life counter: 16.67%
    FBUS INTERFACE NOT CONNECTED!!!
    USB Cable Driver version: 7.1.17.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.21.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.21.ppm_a
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.21.image_a
    Languages in ppm: English,German,Finish,Swedish,Danish,Norwegian,Ice landic
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.21.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.21.image_v_red
    Languages in ppm: English,Chinese Simpl,Chinese T,Vietnamese
    Backing up CRT...
    Detected P-KEY: 9001DF77
    Init usb communication...
    Reading IMEI...
    Failed! Aborting!
    Failed to backup CRT...
    PRESS POWER ON NOW!
    Searching for phone...Found
    Sending RAW loader...
    Using 06.02.002
    Elf2flash 02.33.000 RAW loader...
    Patching RAW boot step1...
    Patching RAW boot step3...
    Sending RAW Loader...
    ...................Loader Sent!
    Stage 2 starting.......................................... ......................Loader Sent!
    Stage 3 starting..................Phone prepared OK!
    Waiting for the phone to boot...
    Phone failed to boot in flash mode CMT...
    Thành viên kỳ cựu HÀ GIANG GSM's Avatar
    Apr 2009
    HÀ GIANG GSM
    bỏ crt 308 chạy 2 fie mcu và ppm thôi nha bạn...100% ok mà tiếng việt là đuôi image v và t mà bạn..
    Thành viên tích cực vantuan_huemobile's Avatar
    Jun 2008
    vùng cao nam đông _huế
    lấy cáp ốp lưng chạy lại cho no' cái ko đc thì làm tavo+rutu đi bạn.thân
    Jan 2008
    Kết quả vẩn vậy, có ai giúp em ko, khách hối quá trời em cảm ơn trước
    Thành viên chính thức tuphilong's Avatar
    Feb 2008
    tốt nhất bạn nên lấy HWK flash lại cái đã.kích pin trên 50% rồi bỏ vào JAF flash USB.good luck!!!
    Cửa hàng ĐTDĐ Thuận Phát.261 lê quang định F7.Q Bình Thạnh
    ĐT:62947474 or 0938438951
    Apr 2009
    HÀ GIANG GSM
    bạn lấy cáp 3110c đi thư cap đi đa mjnh giúp..
    Thành viên tích cực Ti Fone's Avatar
    Jun 2008
    bỏ vao jaf info=>repair BT 1 fat xem sao nha..chuc thanh công
    ai cần chúng tôi...chúng tôi có..
    ai đang khó khăn...chúng tôi lăn xăn giúp đỡ...:p
    Apr 2009
    HÀ GIANG GSM
    mà không nữa mang wa hwk 1 fat ok liền...
    Jan 2008
    JAF ko nhận cáp, HWK thì em ko có, JAF chạy USB thì nó cứ vậy hoài, mong giú em
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    con này hở flash là cái chắc.
  1. Trả lời: 9
  2. Trả lời: 19
  3. Trả lời: 21
  4. 6300 cần giúp
    By hieu08 in forum BB5
    Bài viết cuối: 19-06-2009, 21:38
  5. 6300 đuôi sạc như 6300 xịn sạc tiếp xúc kém
    Trả lời: 21
