mình có 1 máy 3110c dùng khoảng 8 tiếng mất nguồn để nguyên vậy bật không lên đc nguồn phải gỡ pin ra lắp lại bật mới lên nguồn đã chạy ver 7.21 vẫn vậy
anh em xem giúp mình log thank.
đây là log info
MCU SW : V 07.21 05-11-08 RM-237 (c) Nokia.
PPM SW : V 07.21 05-11-08 RM-237 (c) Nokia. V
Prd.Code: 0552795
Bpr.Code: 0542523
Prod.Sn : MKK329557
HW Vers : 5002
EM RETU : 32
EM TAHVO: 53
RFIC Ver: 17211721
DSP Vers: ICPR61_08w10
IMEI : 353081-02-707950-1
SL Serv : SIMLOCK SERVER VERSION 63
SL Conf : 244-07-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland
đây là log write flash
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 0020881C-00006A21, St M58LR256KC
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm237__07.21.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00020000-0007FFFF
CMT NOR Erase Area: 0x00080000-000DFFFF
CMT NOR Erase Area: 0x00100000-001FFFFF
CMT NOR Erase Area: 0x00200000-0031FFFF
CMT NOR Erase Area: 0x00320000-0105FFFF
CMT NOR Erase Area: 0x01060000-01067FFF
CMT NOR Erase Area: 0x01068000-0107FFFF
CMT FLASH ERASE OK, Time: 00:56
Written: 10 Certificate(s)
CMT FLASH WRITE OK, Time: 01:44
Chip SECTOR_SIZE: 128k
Warning, Must be Used 128Kb Sector_Size CNT File
IMAGE : rm237__07.21.image_v_128
CMT NOR Erase Area: 0x01520000-01FDFFFF
CNT FLASH ERASE OK, Time: 00:47
CNT FLASH WRITE OK, Time: 00:35
IMAGE : rm237__07.21.ppm_v
CMT NOR Erase Area: 0x01080000-0151FFFF
PPM FLASH ERASE OK, Time: 00:17
PPM FLASH WRITE OK, Time: 00:31
Flashing Completed, Rebooting Mobile
UI Defaults Ok, Time: 00:29
Set UI Factory Defaults Ok, Time: 00:00
Set Full Factory Defaults Ok, Time: 00:00
Set Software Upgrade Defaults Ok, Time: 00:00
Set Security Ok, Time: 00:00
All Done, Time: 05:49
