Kết quả 1 tới 10 của 11
    Thành viên chính thức tuan_queso5's Avatar
    Apr 2009
    Mặc định nokia n72 xin được giúp đỡ
    mình có con n72 rm-180 tháo ra thay vỏ xong giờ bật nguồn nó lên trắng treo mong ae chỉ giúp.
    đây là log mình info anh em xem giúp
    JAF version 1.98.61
    Detected PKEY: 90025E31
    Card life counter: 47.13%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
    JAF DCT4/BB5 PRODUCT DIR: F:\THU_MOBILE_TQ\SarasSoft\UFS\UFS_DCTxBB5\product s\
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05wk07v47
    30-01-07
    RM-180
    (c) Nokia.
    HW version: 5100
    PCI version:
    RFIC version:  150a160f
    DSP version: rolf_espresso_05wk07v29p1
    Retu version: 32
    Tahvo version: 53
    Production serial number: CTD675506
    Product code: 0531541
    Module code:
    Basic production code: 0530940
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356295015675875
    IMEI spare to net: 3A 65 92 05 51 76 85 07
    IMEI SV to net: 33 65 92 05 51 76 85 07 F6
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini
    Setting local mode...
    Reading product code...
    Product Code: 0531541
    Checking path: F:\THU_MOBILE_TQ\SarasSoft\UFS\UFS_DCTxBB5\product s\RM-180\
    Scanning for ini files...
    MCU Flash file: F:\THU_MOBILE_TQ\SarasSoft\UFS\UFS_DCTxBB5\product s\RM-180\RM180_50734401.C0
    PPM Flash file: F:\THU_MOBILE_TQ\SarasSoft\UFS\UFS_DCTxBB5\product s\RM-180\RM180_50734401.V12
    Languages in ppm: English,Trad Chinise,Indian
    Done!
    Thành viên tích cực cuocsongmoi's Avatar
    Sep 2008
    chạy cho nó luôn đi pro. nhớ backup nhé
    quocchuong566
    Guest quocchuong566's Avatar
    log ok, thử chạy lại, coi lại màn hình socket
    V.I.P HUE_GSM's Avatar
    Mar 2008
    Đến từ Huế city.
    Bạn xem lại cái thẻ nhớ cái xem sao,chúc may mắn.
    Thành viên mới hongquanmobile's Avatar
    Apr 2008
    trang man hinh nhung con nghe goi duoc hok anh
    Thành viên tích cực v&tmobile's Avatar
    Oct 2008
    Ctythegioididong
    cậu đã câu áp chưa ? nhấc ra câu áp cho nó một phát nhé .
    cái này nhiều ngườ hỏi rùi . bạn search đi có cả sơ đồ câu áp luôn đó !
    V.I.P NAMMC's Avatar
    Aug 2007
    ..::Ngoc Linh Mobile::..
    Câu áp Ape cho nó đi bạn rồi chạy lại phần mềm nha bạn ,
    Thành viên tích cực tuongmobil@_1987's Avatar
    NAM ĐỊNH
    con này kiểmtra socket nha! tháo ra thay vỏ mà!
    không tiền đố mi làm nên...........!!!!!!!!!!!
    Thành viên kỳ cựu phone_lucky's Avatar
    bình phước
    trắng treo mà chắc là mất áp rùi, bạn thử info ra rồi đưa log lên là ok
    Aug 2007
    bạn làm theo cái này nhé.thân
  1. Trả lời: 5
  2. Trả lời: 5
    Bài viết cuối: 09-01-2013, 15:47
  3. Trả lời: 5
  4. Trả lời: 10
  5. Trả lời: 25
