Kết quả 1 tới 10 của 10
    Thành viên tích cực thamngocphong's Avatar
    Mặc định xem dùm cái log
    JAF version 1.98.62
    Detected PKEY: 90009B6C
    Card life counter: 99.99%
    USB Cable Driver version: 7.1.8.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-198\
    Checking path: \Products\RM-198\
    No ini files found...
    Detected P-KEY: 90009B6C
    Init usb communication...
    Phone Type:
    Not found!!!
    Phone Type:
    Phone Type:
    MCU Flash file: C:\downloads\6085 RM-198_6.0\rm198__06.00.mcusw.bin
    Phone Type:
    PPM Flash file: C:\downloads\6085 RM-198_6.0\rm198__06.00.image_vg_is
    Phone Type:
    PPM Flash file: C:\downloads\6085 RM-198_6.0\rm198__06.00.ppm_v
    Phone Type:
    CNT Flash file: C:\downloads\6085 RM-198_6.0\rm198__06.00.image_vg_is
    Backing up CRT...
    Failed to backup CRT...
    PRESS POWER ON NOW!
    Searching for phone...Not found!!!
    Not found!!!
    Not found!!!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 1F1001055C206056D14E1E1D895A4B82ADB88158
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 002F0001 <=> SPANSION -> 72NS256N
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Reading CMT NPC certificate...
    Reading CMT VARIANT certificate...
    VARIANT CRT empty, skip save...
    Reading CMT CCC certificate...
    Reading CMT HWC certificate...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35322801369832_CRT_backup _91162.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Reading IMEI...
    Failed! Aborting!
    Failed to backup LCK...
    Manual mode selected, version can't be checked!
    Booting phone...
    Error sync the phone...
    máy lên là mất nguồn lại ..chạy file nàocũng bị như vậy ..xin ý kiến các huynh
    Thành viên tích cực cuocsongmoi's Avatar
    Sep 2008
    kiếm cọng cáp khác đi xem có bị nữa không.
    V.I.P jerrylevu's Avatar
    Jun 2005
    sài gòn
    Kiếm cọng cáp chuẩn khác ( fbus ) , bỏ 308 chạy lại post cái log lên , nếu chạy bằng ver thì bấm vào downgrade .
    Trích Được post bởi jerrylevu Xem bài viết
    em có cáp chuẩn và chạy lun cáp đa năng nhưng vẫn bị vậy ..(xin ý kiến)
    Jun 2005
    sài gòn
    kiểm tra cọng cáp từ hộp tới máy tinh luôn nó vẫn báo không kiếm thấy , bạn thử post cái log check và info không thôi .
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Done!
    Jun 2005
    sài gòn
    Bạn thử vào ô chọn đời máy coi có kiếm thấy RM 198 không . post cái log đầy đủ thiếu khúc đầu .
    ok ...em bỏ 308 và chạy lại đã ok ..nhưng máy này còn một bệnh nưa là ..khi đi xa khỏi TP ko gọi dc ..cái này bị máy hay bị PM hả các huynh ? có ai gặp truờng hợp này chưa ..tại cửa hàng em thì sóng đầy ắp
    V.I.P Hoàng Thiên™'s Avatar
    http://gsmtaynguyen.com
    Bạn coi lại chọn file và ver chạy nha!
    Chọn lại, chạy rồi post log lên!
    Trần Hoàng Thiên
    Jun 2005
    sài gòn
    Thì thử đạp cho nó cái PM sóng cẩn thận bỏ 308 đấy không thì mệt . ok
  1. Trả lời: 5
    Bài viết cuối: 08-05-2014, 10:25
  2. anh em check dùm con ip 5 dùm nhà mạng nào
    By NHẬTMINH_GSM in forum iPHONE 5 - 5s
    Bài viết cuối: 26-10-2013, 09:55
  3. Anh em xem dùm con 6085 bus check bị lỗi gì dùm em với
    By hunglangtu_qb in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-08-2013, 09:11
  4. Xin a/e check dùm con 3gs và tư vấn dùm e
    By keylove779 in forum iPHONE 3Gs
    Bài viết cuối: 03-08-2013, 11:47
  5. Mấy anh xem dùm log n-gate qd dùm
    By minhkhoa_iphone in forum DCT4 - WD2
    Bài viết cuối: 14-12-2009, 14:42
