Kết quả 1 tới 10 của 10
    Thành viên tích cực huuthien's Avatar
    Oct 2007
    Mặc định 3110c bị contac service cần giúp
    máy đang sử dụng bình thường rồi bị luôn em đã nâng lên 7.21 xoá full chạy lại write pm qua sx4crt rồi mà vẫn vậy không hết bác nào có cách khác khôn giúp em với thanks dây là cái log in fo của nó đây mong các bác giúp đỡ
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 0DF00006148A7E569557F951DD00260CB70A15AA
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 89810089 <=> INTEL -> Type not in database
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 07.21
    05-11-08
    RM-237
    (c) Nokia.
    HW version: 2000
    PCI version:
    RFIC version:  17211721
    DSP version:
    ICPR61_08w10
    PPM version: V 07.21
    05-11-08
    RM-237
    (c) Nokia.
    V
    BT MCM version: 06cc-P9.1
    Retu version: 32
    Tahvo version: 53
    Content Pack version: Content: v
    V 07.21
    13-01-09
    RM-237
    (c) Nokia.
    Production serial number: 7F0213742
    Product code: 0514949
    Module code: 0203291
    Basic production code: 0542523
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 351963039037258
    IMEI spare to net: 3A 15 69 03 93 30 27 05
    IMEI SV to net: 33 15 69 03 93 30 27 25 F5
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-237.ini
    Setting local mode...
    Reading product code...
    Product Code: 0514949
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
    Checking path: \Products\RM-237\
    No ini files found...
    Done!
    V.I.P HoangViet902's Avatar
    Sep 2008
    Núi Bà Đen
    vậy bạn dủng thiết bị gì để sx4 vậy , vả sx4 off hay sx4 online vậy
    Oct 2007
    em dùng jaf em chỉ sx4 offline thôi em không sx4 online được mong anh chỉ giúp thanks
    Vi phạm nội quy kubocthep's Avatar
    Oct 2009
    sx4 online mới oke ông bạn àh
    Oct 2007
    em dùng customer care v0.78 sx4 thì nó báo như thế này là sao bác chỉ giúp em với
    We are sorry, but SX4 Service is in a closed beta-stage. When our tests are gonna be completed, its gonna avaible to all of our customers.
    Have Fun!
    kết nối mãi mà không được
    Thành viên tích cực cuocsongmoi's Avatar
    Sep 2008
    Trích Được post bởi HoangViet902 Xem bài viết
    pro chỉ cho anh em biết cách chạy sx4 online luôn đi pro ơi.
    Oct 2007
    con này em phài làm sao đây có ai không giúp em với sao em sx4 on line không được
    Thành viên tích cực huuson_0988's Avatar
    có mxkey hoặc mt box thì sx4 và write pm full là ok thôi
    Thành viên chính thức binhminh2k's Avatar
    Mar 2008
    tp kiên giang
    Trích Được post bởi huuthien Xem bài viết
    kiếm cái box mà sx4 chứ gì nữa ,contact sx4 off ko xinhê gì đâu bạn. nó chỉ sửa mấy bệnh lặt văt : ko hỗ trợ bộ xạc ....
    Thành viên tích cực pham viet huy's Avatar
    thay con RAP chạy lại là ok
    nhó pót lại
  1. 3110c contac service nhờ ae giúp
    By sonfa139 in forum BB5
    Bài viết cuối: 08-07-2013, 15:49
  2. 1661 bị Contac Service cần anh em giúp
    By thaomobilecntv in forum DCT4 - WD2
    Bài viết cuối: 07-07-2010, 08:54
  3. 3110c contac service! cần giúp
    By CHHONGQUAN in forum BB5
    Trả lời: 15
    Bài viết cuối: 15-01-2010, 12:11
