Kết quả 11 tới 17 của 17
    Thành viên mới BaoThanh2_DucCo's Avatar
    Anh onl nick lên đi, bây giờ không biết làm gì luôn
    T4M
    T4M vẫn chưa có mặt trong diễn đàn
    V.I.P T4M's Avatar
    Jun 2007
    Lò mổ IC
    Nhìn cái tiêu đề chẳng biết model gì luôn.Sửa lại nha
    Trường hợp máy của bạn thì làm như sau sẽ flash thành công thôi:
    + Bỏ chọn CRT 308.
    + Bỏ chọn CRT BKP.
    Good luck.
    TRUNG TÂM SỬA CHỮA & BẢO HÀNH ĐTDĐ T4M
    SỬA CHỮA CHUYÊN NGHIỆP-UNLOCK,CHUYỂN HỆ,SỬA LỖI PHẦN MỀM
    40b,NGUYỄN THÁI BÌNH,P.4,Q.TB ÐT: (08)62966082-(08)73000234 YH&SKY: t4_mobile
    Bỏ rồi vẩn vậy thôi thử hết rồi cò đâu
    AF version 1.98.63
    Detected PKEY: 9001D620
    Card life counter: 54.42%
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 06.43
    30-03-07
    RM-78
    (c) Nokia
    HW version: 1000
    PCI version:
    RFIC version:  17211721
    DSP version:  pb05w46v49
    LCD version: SEIKO
    PPM version: V 06.43
    30-03-07
    RM-78
    (c) Nokia
    V
    Retu version: 32
    Tahvo version: 53
    Content Pack version: Content: v
    V 06.43
    30-03-07
    RM-78
    (c) Nokia
    Production serial number: CKK530899
    Product code: 0546368
    Module code:
    Basic production code: 0543954
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 12345610654321?
    IMEI spare to net: 1A 32 54 16 60 45 23 01
    IMEI SV to net: 13 32 54 16 60 45 23 11 F8
    LOCK STATUS:
    CONFIG KEY: 8000000000000006
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-78.ini
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Done!
    Phone Type:
    MCU Flash file: C:\Documents and Settings\addmin\Desktop\rm7830006.430.mcusw
    Phone Type:
    PPM Flash file: C:\Documents and Settings\addmin\Desktop\rm783006.43.ppm_v
    Phone Type:
    CNT Flash file: C:\Documents and Settings\addmin\Desktop\rm7830006.43.image_v
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101013000
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 0D500107DAB40154550A9D39F43654CD6483FC13
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 273F6D55DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 002F0001 <=> SPANSION -> 72NS256N
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Operation took 0 minutes 4 seconds...
    No convertion block detected or file already converted.
    Erasing...
    Operation took 1 minutes 28 seconds...
    Writing...
    Stage 1
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    Sending CMT PUB KEYS...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Sending CMT HASH for PMM_CONF
    Sending CMT HASH for SBIF_CONF
    Operation took 1 minutes 55 seconds...
    Reseting phone...
    PPM: C:\Documents and Settings\addmin\Desktop\rm783006.43.ppm_v
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Operation took 0 minutes 29 seconds...
    Writing...
    Stage 1
    Operation took 0 minutes 35 seconds...
    Reseting phone...
    CNT: C:\Documents and Settings\addmin\Desktop\rm7830006.43.image_v
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Operation took 0 minutes 56 seconds...
    Writing...
    Writing converted flash to 128k page
    Operation took 0 minutes 22 seconds...
    Reseting phone...
    Done!
    Total time: 6 Minutes, 2 Seconds
    DCT4/BB5 counter: 281
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    xem lai giùm em cái nha
    Thành viên tích cực tranhoimobile's Avatar
    Nov 2007
    kiểm tra lại cái cabe và con flat nhé ,
  6. ( tranhoimobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    BaoThanh2_DucCo (26-12-2009)
    cab thì thử rùi cáp mới mua mà còn good còn con flas thì chưa đụng, bây giờ nó hay mất nguồn lên chưa được 1' là tắt nguồn
  8. #7
    Thành viên chính thức thuanloitelecom's Avatar
    Jul 2008
    Xem lại cái này,chọn ver cao hơn xem
  9. ( thuanloitelecom ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. xem dùm blog m22i mất nguồn
    By thaibao113 in forum Phần mềm và các mã lệnh
    Bài viết cuối: 25-11-2012, 11:07
  2. Trả lời: 2
    Bài viết cuối: 28-07-2012, 16:13
  3. ae hướng dẩn giùm e cách repait boot con ss s5230 giùm e với
    By truong25071990 in forum Phần mềm Samsung
    Bài viết cuối: 14-01-2012, 14:57
  4. blog BB5 là gì?
    By Dùng_Thử in forum BB5
    Bài viết cuối: 16-09-2009, 15:40
  5. Thi thiet ke blog nhan phan thuong hap dan^-^
    By ledanh89 in forum GIỚI THIỆU NHỮNG WEBSITE MỚI VÀ LINK HAY
    Bài viết cuối: 13-10-2007, 13:38
