Kết quả 1 tới 4 của 4
    Thành viên tích cực langngo's Avatar
    Jan 2009
    Mặc định long e1100t
    em chậy băng hwk ko boot được em cứ chậy giờ nó têo rồi
    MCU File: e1100tdbic3.cla CRC32: BC2F4D91
    TFS File: e1100tdbic3.tfs CRC32: EF0B8B3F
    CFG File: e1100tdbic3.cfg 4154 byte(s)
    Conneem chậy băng hwk ko boot được em cứ chậy giờ nó têo rồi
    Connect Cable to Switched Off Mobile (with battery)
    Preloader Ok 54, 115200 Baud
    Flashloader Ok
    FLASH Id: SEC, K5N6433ATM
    Erase Done, 56 sector(s), Time: 00:19
    File CRC: 0xBC2F4D91
    Loaded Locale: AR by Almoudamer "GsclTeam"
    MCU Write Done, 5039892 byte(s), Time: 07:56
    File CRC: 0xEF0B8ct Cable to Switched Off Mobile (with battery)
    Flashloader Ok
    File CRC: 0xEF0B8B3F
    TFS Version : TFS4.0_CORONA_01
    Directories : 16
    Max_Files : 52
    Directory : /customer
    Directory : /customer/nvmgr
    Directory : /images
    Directory : /images/idle
    Directory : /images/LargeClock
    Directory : /images/menu
    Directory : /images/org
    Directory : /images/power
    Directory : /images/UCS
    Directory : /images/UCS/Default
    Directory : /images/UCS/Default/cfg
    Directory : /memo
    Directory : /sms
    Directory : /sounds
    Directory : /sounds/default
    Directory : /test
    Files_Count: 52/52
    File: /customer/nvmgr/NvData.dat, Size: 8875
    File: /customer/nvmgr/NvInit.dat, Size: 8875
    File: /customer/nvmgr/nvSize.dbg, Size: 293
    File: /customer/nvmgr/VariantVersion.dat, Size: 2
    File: /images/idle/idle_011.ifg, Size: 11086
    File: /images/idle/idle_021.ifg, Size: 13138
    File: /images/idle/idle_031.ifg, Size: 11772
    File: /images/idle/idle_041.ifg, Size: 11966
    File: /images/idle/idle_051.ifg, Size: 14950
    File: /images/LargeClock/icon.ifg, Size: 324
    File: /images/LargeClock/idle_large_clock_lock.ifg, Size: 142
    File: /images/LargeClock/num.ifg, Size: 3056
    File: /images/menu/00_mainmenu_block_bg.ifg, Size: 2014
    File: /images/menu/00_mainmenu_block_menu01_ani04.ifg, Size: 230
    File: /images/menu/00_mainmenu_block_menu02_ani04.ifg, Size: 236
    File: /images/menu/00_mainmenu_block_menu03_ani04.ifg, Size: 330
    File: /images/menu/00_mainmenu_block_menu04_ani04.ifg, Size: 334
    File: /images/menu/00_mainmenu_block_menu05_ani04.ifg, Size: 330
    File: /images/menu/00_mainmenu_block_menu06_ani04.ifg, Size: 276
    File: /images/menu/00_mainmenu_block_menu07_ani04.ifg, Size: 308
    File: /images/menu/00_mainmenu_block_menu08_ani04.ifg, Size: 236
    File: /images/menu/00_mainmenu_block_menu09_ani04.ifg, Size: 510
    File: /images/org/01_thai_sympopup_bg1.ifg, Size: 780
    File: /images/org/01_thai_sympopup_focus_011.ifg, Size: 696
    File: /images/org/01_thai_sympopup_focus_021.ifg, Size: 698
    File: /images/power/pwron01.ifg, Size: 2850
    File: /images/UCS/Default/cfg/Default-1.thm, Size: 324
    File: /images/UCS/Default/cfg/Default-2.thm, Size: 324
    File: /images/UCS/Default/cfg/Default-3.thm, Size: 324
    File: /images/UCS/Default/cfg/Default-4.thm, Size: 324
    File: /images/UCS/Default/cfg/Default-5.thm, Size: 324
    File: /images/greeting_01.ifg, Size: 3616
    File: /memo/memo_list_file.dat, Size: 804
    File: /sounds/default/Baroque.mid, Size: 2227
    File: /sounds/default/Basic_tone.mid, Size: 1367
    File: /sounds/default/Before sunset.mid, Size: 10870
    File: /sounds/default/Butterfly kiss.mid, Size: 4021
    File: /sounds/default/Chiming tone.mid, Size: 1583
    File: /sounds/default/Classic bell.mp3, Size: 69632
    File: /sounds/default/Dewy Leaves.mid, Size: 13024
    File: /sounds/default/Focus on it.mid, Size: 4749
    File: /sounds/default/Forgotten Promise.mid, Size: 8434
    File: /sounds/default/Funky Marionette.mid, Size: 5563
    File: /sounds/default/Good morning.mid, Size: 4084
    File: /sounds/default/Nightless city.mid, Size: 5250
    File: /sounds/default/Rainbow bridge.mid, Size: 7769
    File: /sounds/default/Samsung tune.mp3, Size: 321536
    File: /sounds/default/Tripping.mid, Size: 799
    File: /sounds/default/Voyage.mid, Size: 7115
    File: /sounds/default/Watercolor painting.mid, Size: 13998
    File: /sounds/default/Wind tone.mp3, Size: 14336
    File: /test/cfg.txt, Size: 4101
    Files Closed
    TFS Unmounted
    TFS Write Done, 600805 byte(s), Time
    Thành viên tích cực van_ninh_mobile's Avatar
    Đồng Nai
    báo loạn xạ mình bó tay luôn.
    Thành viên tích cực nguyenchithan01's Avatar
    chạy có chuẩn ko.
    Học ,Học ,Học Nữa,Học Mãi,Học Đến Khi Không Còn Gì Để Học
    Thành viên chính thức maivanthuat's Avatar
    Aug 2008
    LẤY TOOL NÀY MƯỞM CÔNG COM HWK CHẠY NHA BẠN http://www.4shared.com/file/17853786...11_Fo.html?s=1
    YH thuatmobile ĐT 0935012102 có khi ea cần giúp đỡ! mong ae giúp đỡ khi mình cần
  1. cho em cái game bắn trứng khủng long ip3
    By tranduy959 in forum Ứng dụng dành cho Apple IPhone
    Bài viết cuối: 22-08-2014, 14:09
  2. Buổi off line hoành tráng tại Long Hải.
    By nguyen in forum OFFLINE TRONG & NGOÀI FORUM
    Trả lời: 38
    Bài viết cuối: 12-08-2014, 15:39
  3. anh em xem hộ em long con 2730c-1
    By duybach9x in forum BB5
    Trả lời: 12
    Bài viết cuối: 05-11-2012, 20:38
  4. anh em xem ho cai long
    By langngo in forum BB5
    Bài viết cuối: 20-11-2009, 10:32
