Kết quả 1 tới 8 của 8
    quocchuong566
    Guest quocchuong566's Avatar
    Mặc định log n70 kỳ lạ mời anh em thảo luận
    đây là hai logo của hai máy n70. anh em hãy sem và cho ý kiến về hai con máy này.
    N70 bình thường
    Using device: J.A.F, FW ver: 01.B1
    Library version: 1.0.0.11446, Date: 25-11-2009
    APE Data :
    SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
    ASIC MODE ID: 00
    PUBLIC ID: 81ADEE6985EE73976787DD21F1BF35ECA155E55C
    ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
    ROM ID: AB5E4ADB27A06946
    RAP Data :
    SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 121002100C664651EFBAA4DB11EF76A1F4AE8324
    ASIC MODE ID: 00
    ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
    ROM ID: F28A211FCEA7B19D
    SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
    Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
    FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,RAP
    ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
    ExtDEVC: FFFF 0000 - 0000 0000
    Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
    SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
    Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
    FlashID0: 00EC 0036 - 005A 003F [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE
    ALG [35]: OMAP1610 GBBM-1.8.1 ALG
    ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000
    Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908
    APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
    Original Imei: 35291302181073
    Original Product code: 0539276
    Bluetooth ID: 001F01915CC8
    Phone Type: RM-84 (Nokia N70)
    SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia.
    Imei plain: 35291302181073-2
    Product Code: 0539276
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 352913021810732
    Version: SIMLOCK SERVER VERSION 58
    Provider: Nokia Test, Country: Finland
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    N70 kỳ lạ
    APE Data :
    ASIC MODE ID: 00
    PUBLIC ID: 3E3B4ED45DDBEA6FCA34CCE590D8A66705CC9C11
    RAP Data :
    EM0 ID: 00000232
    EM1 ID: 00000352
    PUBLIC ID: 1880001371A949517B8F08A62B753858549A4F23
    ASIC MODE ID: 00
    FlashID0: 0001 0002 - 0000 0111 [AMD NA] type: NOR,RAP
    FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE
    Original Imei: 35792700809607
    Original Product code: 0530324
    Bluetooth ID: 0015A0772A51
    Imei plain: 35792700809607-8
    Product Code: 0530324
    Language Pack:
    - not available.
    SIMLOCK_TEST passed
    Imei net: 357927008096078
    Provider: Hutchinson 3G (3), Country: United Kingdom
    Counter: 0/3, 0/10
    CONFIG_DATA: 2342000000000000
    BLOCK 1: 1=OPEN, DATA=23420F
    BLOCK 2: 1=OPEN, DATA=23594F
    BLOCK 3: 1=OPEN, DATA=23420F
    BLOCK 4: 1=OPEN, DATA=23594F
    hai máy vẫn sài ok các chức năng nhưng máy thứ hai ( n70 kỳ lạ) thì không cho phép sài các fim như menu,nút đỏ, nhạc, và camara,fm, không cho sài,
    Thành viên tích cực giaphu_dn's Avatar
    Feb 2009
    bác có mở hai cái men bo máy ra nghía chưa vậy, xem nó có khác gì không?
    http://www.nckcode.com
    Thành viên tích cực binhdtdd's Avatar
    Sep 2008
    bạn mở main ra sẽ có lời giải thích liền ,coi chừng main china đó
    0933.379.527
    quocchuong566
    Trích Được post bởi binhdtdd Xem bài viết
    cả hai men điều là hàng zin hai bạn
    quocchuong566
    Counter: 0/3, 0/10
    Counter: 0/3, 0/10
    chỗ khác nhau về log, nhìn cái logo của n70 kỳ lạ y như là đang bị lock, nhưng đã thử mở mạng lại vẫn vậy
    Thành viên mới lcd_a2000's Avatar
    Jan 2010
    KHI ĐOC BÀI VIẾT NÀY,BẠN ĐỪNG BỎ QUA NGAY,HÃY ĐỂ MỘT CHÚT THỜI GIAN MÀ ĐỌC THỦ XEM SAO
    TÔI NGHĨ ANH EM ĐIÊN THOẠI CHÚNG MÌNH RẤT THUẬN TIỆN CHO CÔNG VIỆC NÀY ĐÓ LÀ {KIẾN TIỀN QUA INTERNET}
    PHẦN MỀM KIẾM RA TIỀN NÈ! Hãy thử 1 lần!
    Cách kiếm tiền trên mạng nhiều nhất và dễ nhất - click vào và đăng ký ngay nhé!!$$$$$$$$$$$$. http://tickerbar.info/join_now.ghc?r=231832474
    Chỉ cần ngồi một chỗ trên mạng, bạn cũng có thể có một số tiền khổng lồ hàng tháng bằng cách quảng cáo cho những trang web nuớc ngoài Greenhorse. Bạn hãy đăng ký vào đây và giới thiệu càng nhiều nguời đăng ký càng tốt, bạn sẽ có một số tiền khổng lồ. Bạn là bất kỳ ai, sinh viên hay là học sinh, đang đi làm hay có mong muốn kiếm việc để có thêm thu nhập. Bạn đang cần tiền ? hãy tận dụng.
    Sau chỉ có 2 tuần lễ mình đã bất ngờ nhận được thư chuyển tiền của Greenhorse, mà lại là thư bảo đảm hẳn hoi chứ. Thật không thể tin nổi !!! Mình đã có trong tay 90$ đầu tiên, khi mà mình chẳng phải làm gì cả. Tôi biết chắc các bạn còn ngần ngại và hoài nghi bởi làm gì mà dễ dàng như thế . Nhưng đây là sự thật hoàn toàn. - Bạn hãy thử xem!
    Mở trang web này lên nè,nhớ Copy và Paste cho chính xác:
    bạn sẽ thấy những yêu cầu và điền vào:
    * Buớc 1:
    - Email address : địa chỉ mail của bạn.
    - First name / last name : họ và tên.
    - Birthday: tháng/ngày/năm sinh
    - Gender (giới tính) : chọn \\\"male\\\" nếu bạn là nam, chọn \\\"female\\\" nếu bạn là nữ.
    - Own Credit Card : chọn No (dù có hay không)
    - Country : Vietnam
    - TERMS OF SERVICE : chọn YES.
    Sau khi diền dầy dủ thông tin, hãy click chuột vào mục \\\"Go To STEP 2\\\"
    * Buớc 2 :
    - Password : mật khẩu (bạn tự chọn một mật khẩu cho mình rồi diền vào)
    - Confirm : đánh lại mật khẩu một lần nữa dể xác nhận.
    -pass word question :la 1 cau hỏi tự đặt ra ( vd :what is my name? ). --- -pass word answer :la 1 cau tra loi cho câu hỏi trên (vd: TUNG,… )
    - Time Zone : chọn Vietnamese…(VST) . –
    - Phone Number: 84/.../...... (điền số ĐT của bạn vào, phải kèm theo mã nuớc 84 ở ô thứ nhất, mã vùng ở ô thứ hai (ví dụ: nếu bạn ở TP. Hồ Chí Minh thì mã vùng là 08, cuối cùng là số diện thoại của bạn.)
    - Spoken Language: Vietnamese
    - Secondary Language: Vietnamese
    - Street Address: địa chỉ nhà (chính xác ,không dấu)
    - Street Address_2: dịa chỉ nhà thứ 2 (nếu có)
    - City/Region: VD Ha Noi,Ho Chi Minh,Binh Dinh….(tinh,TP noi ban sinh song)
    - State/Province: VD Ha Noi …(tinh,TP noi ban sinh song)
    - Zip/code:Mã bưu chính
    ( M ã này rất quan trọng, nhớ ghi cho đúng ! )
    *Bạn tra cứu bảng mã ZIP CODE ở danh sách sau va chọn cho đúng để điền vào:
    Quảng Ninh : 36000 _ TP. Hà Nội : 10000 _An Giang : 94000 _Bà Rịa Vũng Tàu : 74000 _ Bạc Liêu : 99000 _Bắc Kạn : 17000 _Bắc Giang : 21000 _Bắc Ninh :16000 _Bến Tre 3000 Bình Dương :72000 _Bình Định :53000 _Bình Phước: 77000 _Bình Thuận :62000 Cà Mau: 96000 _Cao Bằng: 22000 _Cần Thơ - Hậu Giang: 92000 _TP. Đà Nẵng :59000 ĐắkLắk - Đắc Nông :55000 _Đồng Nai :71000 _Đồng Tháp: 93000 _Gia Lai :54000 Hà Giang :29000 _Hà Nam :30000 _Hà Tây :31000 _Hà Tĩnh :43000 _Hải Dương :34000 TP. Hải Phòng :35000 _Hoà Bình :13000 _Hưng Yên :39000 _TP. Hồ Chí Minh :70000 Khánh Hoà :57000 _Kiên Giang :95000 _Kon Tum :58000 _Lai Châu - Điện Biên: 28000 Lạng Sơn :20000 _Lao Cai :19000 _Lâm Đồng: 61000 _Long An 1000 _Nam Định: 32000 Nghệ An :42000 _Ninh Bình :40000 _Ninh Thuận: 63000 _Phú Thọ: 24000 _Phú Yên :56000 Quảng Bình :45000 _Quảng Nam :51000 _Quảng Ngãi :52000 _Quảng Ninh :36000 Quảng Trị :46000 _Sóc Trăng :97000 _Sơn La :27000 _Tây Ninh :73000 _Thái Bình :33000 Thái Nguyên: 23000 _Thanh Hoá: 41000 _Thừa Thiên Huế :47000 _Tiền Giang 2000 Trà Vinh: 90000 _Tuyên Quang :25000 _Vĩnh Long :91000 _Vĩnh Phúc :11000 _Yên Bái :26000
    - Occuption: chọn nghề nghiệp của bạn ( chắc là sinh viên và học sinh)
    - Income : chọn less than $24,999
    - Parental Consent : click chuột để đánh dấu vào ô trống(chọn)
    Sau khi hoàn thành, hãy click chuột vào \\\"GO TO FINAL STEP\\\"
    * Buớc 3:
    Click vào \\\"Activate Account\\\"
    Click vào dòng màu dỏ (dowload.........) để DOWNLOAD TICKERBAR 211736156 .exe
    Sau đó click vào biểu tượng TickerBar để Install. Khi bạn chạy chương trình TickerBar trên máy tính của bạn sẽ xuất hiện dòng chữ chạy phía trên cùng của màn hình máy tính, đó là lúc TickerBar được khởi động và thời gian tính tiền cho bạn là TickerBar online 1h = bạn được 0.01 $. Bạn cần giới thiệu cho nhiều người để có thể nhận tiền thưởng vào tk của mình
    * Xong rồi dó! Bây giời bạn chỉ việc copy bài viết này của tôi gởi mail cho bạn bè hoặc đăng trên các diễn đàn mà bạn đang tham gia để giới thiệu cho nhiều nguời (bằng account của bạn ) để mọi người cùng đăng ký (giống như mình đã giới thiệu cho bạn ) Bạn hãy yên tâm!Nếu bạn kiếm được càng nhiều tiền thì Greenhorse càng được nhiều lợi nhuận từ công việc quảng cáo và đương nhiên họ sẽ phải rất quan tâm và giữ uy tín với bạn! Vậy bạn đừng chần chừ gì nữa mà không click vào đây: http://tickerbar.info/join_now.ghc?r=231832474
    * Cách giới thiệu:
    Khi thực hiện dang ký xong bạn sẽ nhận đuợc một mail từ GreenHorse, báo cho bạn biết link của bạn. Bạn hãy copy bài viết này ra thành nhiều bản và dang (miễn phí) trên những trang web nhu hanoimuathu.net, thuyhu.com, raovat.net... dể giới thiệu cho nhiều nguời. Khi dang, bạn phải thay link của bạn vào dịa chỉ liên kết.
    * Cách tính tiền:
    -Bạn giới thiệu 10 nguời bạn sẽ đuợc 10$ (USD) (10 đô la Mỹ)
    10 nguời này giới thiệu thêm 10 nguời nữa bạn sẽ đuợc 100USD,10 người này tiêp tục giới thiệu thêm 10 nguời nữa bạn sẽ đuợc 1000USD,...
    và cứ tiếp tục nhu thế....
    Với một chút quyết tâm và may mắn bạn sẽ có một khoản tiền khổng lồ mỗi tháng!!!
    -Greenhorse trả tiền cho bạn thông qua thời gian bạn sử dụng thanh Ticker. Mục đích đăng kí của Greenhorse là \\\"Càng nhiều người tham gia càng nhiều tiền.\\\". Bạn có thể dùng file down về chạy trên nhiều máy khác nhau, kể cả ở dịch vụ internet.Hãy giới thiệu cho bạn bè bạn biết để cùng tham gia. Hãy nhớ: Chỉ cần có người tham gia Greenhorse thông qua giới thiệu của bạn là bạn có tiền thưởng. Tài khoản của bạn sẽ sử dụng được nếu trên 90$. Số tiền sẽ được gửi về định kì theo địa chỉ bạn đăng kí ở trên
    Chúc bạn may mắn!
    Hãy vào địa chỉ liên kết này và thực hiện ngay nhé!!! http://tickerbar.info/join_now.ghc?r=231832474
    Tại sao ko click ngay vào link trên để bắt đầu sự nghiệp làm giàu cho mình - mình giới thiệu cho bạn , bạn click , bạn lại giới thiệu cho người khác - bạn lợi , mình lợi , đôi bên cùng có lợi . Lúc đầu có thể lượng tiền tăng hơi chậm, nhưng nếu bạn biết phát triển mạng lưới như trên thì tốc độ tăng tiền sẽ theo cấp số nhân. Đừng vội nản lòng.
    Sau khi đăng kí , hãy giới thiệu cho nhiều người biết để làm giàu cho bạn.
    Khi cần kiểm tra tài khoản của mình,bạn chỉ cần mở trang web: http://tickerbar.info
    ,vào member login để đăng nhập vào theo địa chỉ mail và password đã đăng ký lúc đầu
    Chúc các bạn sớm thành công!
    Feb 2009
    [QUOTE=lcd_a2000;454672]KHI ĐOC BÀI VIẾT NÀY,BẠN ĐỪNG BỎ QUA NGAY,HÃY ĐỂ MỘT CHÚT THỜI GIAN MÀ ĐỌC THỦ XEM SAO
    * Buớc 1:
    - Country : Vietnam
    * Buớc 2 :
    * Buớc 3:
    * Cách giới thiệu:
    * Cách tính tiền:
    Chúc bạn may mắn!
    Chúc các bạn sớm thành công![/
    THẰNG NÀY Ở ĐÂU RA VẬY CÁC MOD ƠI
    Thành viên tích cực hoangthanhmobilee's Avatar
    Nov 2008
    mytho. tien giang
    ủa?????? đang nói về N70 tự nhiên quảng cáo trên đây vậy kìa.
    hình như banh cái này rồi, bạn sx4 rồi nạp pm,unlock thử xem sao bạn.
    yahoo: hoangthanhmobilee
    DT : 0909168878
  1. thảo luận về 3gs 6.16
    By vanthangmobile91 in forum iPHONE 3Gs
    Trả lời: 15
    Bài viết cuối: 27-02-2014, 17:28
  2. Ace vào thảo luận xem nó là bệnh gì
    By SƠN CÒI_GSM in forum DCT4 - WD2
    Trả lời: 32
    Bài viết cuối: 27-11-2012, 06:49
  3. thảo luận
    By Apple179 in forum BB5
    Bài viết cuối: 19-09-2010, 15:44
  4. Thảo luận về cách độ cáp
    By shockcuteboy in forum BB5
    Bài viết cuối: 09-06-2009, 22:12
