Kết quả 1 tới 2 của 2
    T4M
    T4M vẫn chưa có mặt trong diễn đàn
    V.I.P T4M's Avatar
    Jun 2007
    Lò mổ IC
    Mặc định E75-1_rm-412 flash tv ok.
    Code:
    JAF version 1.98.63
    Detected PKEY: 9000B296
    Card life counter: 27.20%
    FBUS INTERFACE NOT CONNECTED!!!
    USB Cable Driver version: 7.1.14.0
    Changing mode...Done!
    Detected P-KEY: 9000B296
    Init usb communication...
    Found
    Init usb flashing...
    Reading flashid...
    CMT: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA
    APE: 00000000 <=> Flash -> not detected
    Done!
    Searching for phone...Detected P-KEY: 9000B296
    Found
    MCU SW version: V ICPR72_09w04.3
    05-03-09
    RM-412
    (c) Nokia
    HW version: 0500
    PCI version:
    RFIC version:
    DSP version:
    APE SW Core version: 100.48.78
    APE Variant version: 100.48.78_rofs2100.48.78_rofs3
    APE Test version: RM412ENOx2008wk50v0.017
    Retu version: 15
    Tahvo version: 22
    APE HW version: 256
    APE ADSP SW version: 256
    APE BT version: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.
    Content Pack version: 100.48.78
    Production serial number: CNJ880869
    Product code: 0574275
    Module code:
    Basic production code: 0558819
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 356855021285256
    IMEI spare to net: 3A 65 58 05 12 82 25 05
    IMEI SV to net: 33 65 58 05 12 82 25 05 F3
    LOCK STATUS:
    CONFIG KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Loading INI list...
    Reading product code...
    Product Code: 0574275
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-412\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\
    No ini files found...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Done!
    Found
    05-03-09
    RM-412
    (c) Nokia
    HW version: 0500
    PCI version:
    RFIC version:
    DSP version:
    Retu version: 15
    Tahvo version: 22
    APE HW version: 256
    Module code:
    Flash code:
    Order number:
    ATO:
    Default SN type:
    LOCK STATUS:
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Loading INI list...
    Scanning ini files...
    MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\rm412_1004878_prd.c00
    PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\rm412_1004878_prd_prdapps.rofs2.v34
    CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\rm412_1004878_prd_prdapps.rofs3.v34
    APE Variant file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\rm412_1004878.02U
    Done!
    Changing flashing settings...
    Reading...
    PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\rm412_1004878_prd_prdapps.rofs2.v43
    CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\rm412_1004878_prd_prdapps.rofs3.v43
    APE Variant file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\rm412_1004878.03U
    Backing up CRT...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\356855021285256_CRT_backup_122496.pm
    Done!
    Backup CRT OK!
    Searching for phone...Found
    Reading SW version...ICPR72_09w04.3 100.48.78
    Reading battery value...4035 mV
    Reading flashid...
    Verifing ADL communication... Status byte 7
    Rebooting to flash mode...
    Waiting for the phone to reboot...
    Sending RAW loader...
    Using 007.016.022
        Elf2flash 08.37.001
        CMT RAW loader...
    Sending RAW Loader...
    ....................Loader Sent!
    Stage 2 starting..............Phone prepared OK!
    Waiting for the phone to boot...
    Status byte: 8000
    Selecting CMT flash...
    Result: 0000
    Phone is in flash mode...
    CMT blocks: 526, APE blocks: 0
    Erasing cmt...
    Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\rm412_1004878_prd.c00...
    Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
    Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
    Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
    Erasing cmt zone 00D60000 - 09F7FFFF ... Erase result: 0000
    Partition result: 0014
    Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\rm412_1004878_prd_prdapps.rofs2.v43...
    Erasing cmt zone 07200000 - 08B7FFFF ... Erase result: 0000
    Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\rm412_1004878_prd_prdapps.rofs3.v43...
    Erasing cmt zone 08B80000 - 09F7FFFF ... Erase result: 0000
    Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-412\rm412_1004878.03U...
    Erasing cmt zone 09F80000 - 0F71FFFF ... Erase result: 0000
    Send CMT CFG...
    Writing cmt...
    Sending CMT HASH for ADA
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for RAP3NAND
    Sending CMT HASH for PASUBTOC
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    Sending CMT HASH for SOS*UPDAPP
    Sending CMT HASH for SOS*DSP0
    Sending CMT HASH for SOS*ISASW
    Sending CMT HASH for SOS+CORE
    Sending CMT HASH for SOS+ROFS1
    Sending CMT HASH for SOS+ROFS2
    Write result 27: 1701
    Sending CMT HASH for SOS+ROFS3
    Rebooting...
    Finishing CMT session...
    Restarting CMT...
    Pooling phone...
    MCUSW: V ICPR72_09w04.3
    05-03-09
    RM-412
    (c) Nokia
    APESW: 100.48.78
    VariantSW: (null)
    Prodcode: 0574275
    Done!
    Thấy cách chọn file hơi lạ nên post ae tham khảo.
    Flash via USB chưa đầy 1 phút báo done--->hết hồn nhưng ok.
    TRUNG TÂM SỬA CHỮA & BẢO HÀNH ĐTDĐ T4M
    SỬA CHỮA CHUYÊN NGHIỆP-UNLOCK,CHUYỂN HỆ,SỬA LỖI PHẦN MỀM
    40b,NGUYỄN THÁI BÌNH,P.4,Q.TB ÐT: (08)62966082-(08)73000234 YH&SKY: t4_mobile
  2. ( T4M ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    phanngocru (24-02-2010), QuốcỨngMobileST (09-07-2009)
    Thành viên mới phanngocru's Avatar
    Feb 2010
    Bạn chạy ver nào vậy? Nếu có TV ver 202.12.01 thì cho mình xin nhé, mình đang rất cần. Cảm ơn bạn nhiều.
  1. Trả lời: 7
    Bài viết cuối: 18-10-2013, 09:52
  2. n91-1_rm-43 xin được giúp đỡ
    By tuan_queso5 in forum BB5
    Bài viết cuối: 29-08-2010, 00:38
  3. Trả lời: 2
    Bài viết cuối: 06-01-2010, 23:17
  4. Trả lời: 3
    Bài viết cuối: 22-06-2009, 17:00
  5. xin files 5310 chip 6225 flash FLASH TOSHIBA TV00578002DABD
    By tuthanwwww in forum Phần mềm và các mã lệnh
    Bài viết cuối: 16-04-2009, 09:46
