anh em cho mình xin ý kiến làm như thế nào,hiện trạng khởi dộng màn hình trắng +đèn bàn phím sáng.2 cái đó cứ treo sáng hoài,giúp em với
 n72 bị đập trắng màn hình
Học ,Học ,Học Nữa,Học Mãi,Học Đến Khi Không Còn Gì Để Học
				con nghe gọi j dc ko bạn,nếu còn tốt a coi manin có bị mất tụ hay ic j ko rồi tình tiếp
				JAF version 1.98.62
Detected PKEY: 9000AAC9
Card life counter: 99.99%
USB Cable Driver version: 7.1.17.0
Changing mode...Done!
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101012200
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 0D20021321AF60515F43B9D30D6AEF244778EB7C
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 00330001 <=> SPANSION -> Type not in database
CMT Loader Ready
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05wk07v48.1
28-08-07
RM-180
(c) Nokia.
HW version: 7001
PCI version:
RFIC version: 150a160f
DSP version: rolf_espresso_05wk07v29p1
Retu version: 32
Tahvo version: 53
Production serial number: DQD471401
Product code: 0531540
Module code:
Basic production code: 0530940
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 359570010131323
IMEI spare to net: 3A 95 75 00 01 31 31 02
IMEI SV to net: 33 95 75 00 01 31 31 02 F8
LOCK STATUS:
CONFIG KEY: 0000000000000000
Provider: AT&T;U.S.A. (3650)
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini
Setting local mode...
Reading product code...
Product Code: 0531540
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\
Checking path: \Products\RM-180\
No ini files found...
Done!
				và đây là log em chạy
JAF version 1.98.62
Detected PKEY: 90009699
Reading...
28-08-07
RM-180
(c) Nokia.
HW version: 7001
PCI version:
Retu version: 32
Tahvo version: 53
Module code:
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
LOCK STATUS:
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
Reading...
28-08-07
RM-180
(c) Nokia.
HW version: 7001
PCI version:
Retu version: 32
Tahvo version: 53
Module code:
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
LOCK STATUS:
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Scanning for ini files...
INI file 0531540.ini is missing. Continue searching for second ini type...
Done!
Phone Type:
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50819401.C0
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50819401.V01
Languages in ppm: English,French,German,Italian,Spanish,Portuguese
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\35957001013132_CRT_backup _115813.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\359570010131323_CRT_backu p_115913.pm
Done!
Backup LCK OK!
Preparing for downgrade...
Phone ready for downgrade!
Manual mode selected, version can't be checked!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Operation took 0 minutes 6 seconds...
Sending CNF Data...
APE blocks present in flash file but no APE mcu detected in phone. Aborting!
				Đính kèm 25627 bạn câu theo hình này xem sao
				câu lại áp thử anh
dienthoaididong_truongthinh
				câu áp APE lại đi anh,mất áp rùi
				em nghĩ máy này bị đứt đường từ rap đến omap rồi. đóng con rap lại xem sao, nếu không hết thì đục luôn con omap.
				bạn câu lại áp APE rùi flash lại xem sao!
Mobile Service Center: THÀNH HƯNG™
AGRIBANK:Huỳnh Thành Hưng - 7605205010569
Y!M: hung_thanhhung2002
				câu như hình bạn vn_mobile_gsm cũng vậy,ai có cao kiến khác ko
