check lại con Flash nhé . trước mình cũng bị trường hợp này .
cái dụ này hơi khó đấy , anh thử dùng JAF info 1 cái rồi quen lên cho anh em chim ngưỡng coi
Phone is in: Local mode
Scanning files, please wait...
Done
Model: RM-223 (N81-3)
V 06wk41v62.5/11-05-09/RM-223 (c) Nokia
Production serial number CMF040294
Product code 0550106
Module code 0203265
Basic production code 0545926
Flash code
Order number
Long production SN 0
MCU SW V 06wk41v62.5/11-05-09/RM-223/(c) Nokia
HW 0541
PCI
RFIC 17141715
DSP bruce_mc.ICPR62_08w28
APE SW Core 22.0.002
APE Variant 22.0.00222.0.002_16.01
APE Test rm223_ENO_x_2007wk24v0.060
Retu 15
Tahvo 22
APE HW 256
APE ADSP SW 256
IMEI: 356994011615485
WARNING: VPP pin is not connected, disabling VPP.
Selected Highest installed version: 22.0.002
Mcu RM223_22.0.002_prd.C00
Ppm RM223_22.0.002_prd_1601.V16
Content RM223_22.0.002_004_000_U05_uda.fpsx
Factory Default Settings(max wait 2 min)... Successfull
Format user area (max wait 2 min)... Failed
Low level format NAND ... Failed
Successfull, code is 12345
Using Tx2 Data line.
BB5 PM back Phone is in: Local mode
Backup file: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\RM-223_356994011615485.pm
Processing File: RM223_22.0.002_prd.C00
Boot...
RAPIDOv11_2nd.fg
RAPIDOv11_algo.fg
CMT Certificates
NPC 0x0200
HWC 0x0100
CCC 0x0200
C:\Program Files\GriffinTeam\MT-Box\rpls\356994011615485.rpl
Erase RAP3 [00040000 - 00082FFF]
Erase RAP3 [00083400 - 0087FFFF]
Erase RAP3 [00B80000 - 05F7FFFF]
Erase[92.25 MB]...
Waiting response for 320 Sec...in 3.84s
Flash[44.91 MB]...in 69.13s
* * Processed file in 82.25 seconds
Processing File: RM223_22.0.002_004_000_U05_uda.fpsx
Boot...
RAPIDOv11_2nd.fg
RAPIDOv11_algo.fg
Erase RAP3 [05F80000 - 079DFFFF]
Erase[26.38 MB]...
Waiting response for 320 Sec...in 0.59s
Flash[0.07 MB]...in 0.75s
* * Processed file in 13.97 seconds
Extract content...OK
Processing File: RM223_22.0.002_prd_1601.V16
Boot...
RAPIDOv11_2nd.fg
RAPIDOv11_algo.fg
Erase RAP3 [03730000 - 05F7FFFF]
Erase[40.31 MB]...
Waiting response for 320 Sec...in 0.80s
Flash[25.93 MB]...in 39.01s
* * Processed file in 47.95 seconds
* * * Phone flashing done in 2:51 minutes
Post Flash serial tunning of phone....
Pooling mode for full factory set...
Factory Default Settings...OK
Sending PMM File:
RM-223\RM-223_repair.pm
Reset user code...Successfull, code is 12345
đây là toàn bộ quá trinh em info va flash đó
bây giờ may N81 Phone start-up failed. Contact retailer la bị gì vậy
Module code 0203265
Flash code
Order number
HW 0541
PCI
RFIC 17141715
Retu 15
Tahvo 22
APE HW 256
APE ADSP SW 256
mấy anh xem thử chỉ em nha
Xin giúp n81 -Rm-223 rớt nước
Nhờ Anh Em đẵ từng gặp và làm qua pan này giúp
Mình nhận cây n81 bị rơi nước cứ lên chữ NOKIA rùi lại quay lại vài lần như vậy rùi tắt luôn ?
Đẵ làm :
Tẩy Main = Tình trạng vẫn thế
Chạy lại + SX4 OK hết = Vẫn như vậy
Làm lại chân :N2200 + N2300 + Rapido D2800 + Flash D300 kết quả = Vẫn lên NOKIA vài lần rùi tắt hẳn
Đây là log chạy HWK
1ST BOOT : C0,07 [Rm-223] [2.0.9.0]
RAPx ID : 000000010000022600010006400C192101021103
EM 1 ID : 00000295
EM 2 ID : 00000B22
RAPx PBID : 1B50010FEB7C005279B95B9866D533B7F767F283
RAPx MODE : 00
RAPx HASH : 9A28E119033B91D14D22838C86D0D53C
RAPx ROID : A8C1D6713E691FF8
CMT 1ST Boot OK
CMT 2ND Bt: RAPIDOv11_2nd.fg, Ver: 1.37.1
CMT FLID0 : 00EC0030-00600221, Sam OneNAND-1G
CMT FLCNT : 00030000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAPIDOv11_algo.fg, Ver: 1.40.0
CMT KSIG0 : E70C21157D5AB5AF61AAD376910751FB06D6E9FD
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : RM223_21.0.010_prd.C00
CMT NAND Erase Area: 0x00040000-00082FFF
CMT NAND Erase Area: 0x00083400-0087FFFF
CMT NAND Erase Area: 0x00B80000-05F7FFFF
CMT NAND Partition Format
CMT FLASH ERASE OK, Time: 00:01
Written: 11 Certificate(s)
CMT FLASH WRITE OK, Time: 04:19
IMAGE : RM223_21.0.010_prd_1601.V16
CMT NAND Erase Area: 0x03730000-05F7FFFF
PPM FLASH ERASE OK, Time: 00:00
Written: 1 Certificate(s)
PPM FLASH WRITE OK, Time: 02:28
IMAGE : RM223_21.0.010_004_000_U05_uda.fpsx
CMT NAND Erase Area: 0x05F80000-079DFFFF
CMT NAND Erase File: SOS-USER
CNT FLASH ERASE OK, Time: 00:00
CNT FLASH WRITE OK, Time: 00:01
Flashing Completed, Rebooting Mobile
info bằng HWK
MCU SW : V 06wk41v62.4 04-12-08 RM-223 (c) Nokia
APE Core: 21.0.010
APE Var : 21.0.01021.0.010_16.01
Prd.Code: 0550094
Bpr.Code: 0541202
Prod.Sn : CRF383541
HW Vers : 0542
APE HW : 256
APE Adsp: 256
EM VILMA: 15
EM BETTY: 22
RFIC Ver: 17141715
DSP Vers: bruce_mc.ICPR62_08w28
WLAN Id : FA8AF7CF25
IMEI : 351935-03-328890-5
SL Serv : SIMLOCK SERVER
SL Conf : 244-07-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland
Đây là info bằng MX key :
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM1 ID: 00000295
EM2 ID: 00000B22
PUBLIC ID: 1B50010FEB7C005279B95B9866D533B7F767F283
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0030 - 0060 0221 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0
RAP PAPUBKEYS HASH: E70C21157D5AB5AF61AAD376910751FB06D6E9FD
Original Imei: 35193503328890
Original Product code: 0550094
Bluetooth ID: 0025CFF6EEBA
WLAN ID: 0025CFF78AFA
Phone Type: RM-223 (Nokia N81)
SW Version: V 06wk41v62.4 04-12-08 RM-223 (c) Nokia
Imei plain: 35193503328890-5
Product Code: 0550094
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2009-01-30T11:48:58+05:30
SW Version: 21.0.010
Variant Version: 210
ProductProfile: RM223_0550094_21.0.010_210.spr
Simlock: RM223_simlock_3gstandard_bb5.bin
Imei: 351935033288905
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
TÌNH TRẠNG MÁY EM GIỜ BỊ Y CHANG NHƯ VẬY NÈ MẤY ANH
sao ko ai giúp em hết vậy,ai làm ok con này thì pm với mình số dt 0906114747.
