    Thành viên mới thai.nokia1's Avatar
    Mặc định xin giúp log 3110c
    mình có con 3110c không vào máy nghe nhạc được. khi chạy chương trình thì nó báo như vậy,ae xem giúp cái log :
    Checking path: \Products\RM-237\
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
    Scanning ini files...
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_v
    APE Variant file: NONE
    Languages in ppm: English,Chinese T,*******ese
    Done!
    Backing up CRT data...
    Setting FLASH MODE
    Loader version: 01.10.02 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 89810089 <=> INTEL -> Type not in database
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg
    Loader version: 01.0C.05 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Reading CMT NPC certificate...
    NPC crt not available...
    Reading CMT VARIANT certificate...
    VARIANT CRT not available...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\12345678901234_CRT_backup _659173.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\359343024901176_CRT_backu p_659173.pm
    Done!
    Backup LCK OK!
    Reading SW version...07.21
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 1A80020F3C267E5627E02B92A2B4D15B9DEAEC4E
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv3_2nd.fg
    CMT Boot Ready
    CMT Loader Ready
    Operation took 0 minutes 6 seconds...
    Sending CRT data...
    Error in RD cmd...
    Error preparing flashing...
    rồi tới đó là đứng luôn, mong ae giúp đỡ
    Thành viên chính thức nd mobile's Avatar
    Jun 2007
    thay cáp good rồi chạy lại xem sao
    Đức Phú Mobile. Đ/C:Trực Ninh- Nam Định
    Đt:0973758989-Y!H: triduc_05@yahoo.com
    Thành viên tích cực ĐìnhThắngMobile™'s Avatar
    GSMobifone
    Dùng dây USB chạy lại đi pro_chạy bản vr7.21 xem sao
    mình đã thử hết rồi,thử cáp đa năng luôn mà vẫn như vậy.dùng usb thì không chk và info được. ae có cao kiến gì nữa không xin giúp đỡ
    GSMobifone
    Trích Được post bởi thai.nokia1 Xem bài viết
    làm gì phải chek và ifo__chọn file rùi cắm dây vô máy chạy luôn_bạn để ý pin còn nhìu điện nha
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    chạy cho nó ít nhất 2,3 box gì đó rồi mới tính sau anh nhé.
    nhiều lúc box này chạy không qua hêt nhưng box khác thì lại ok đó anh.
  1. Xin giúp gấp 3110c
    By VanHiep_mobile in forum BB5
    Trả lời: 14
    Bài viết cuối: 24-11-2012, 17:35
  2. 3110c mất đèn cần anh em giúp.
    By nguyenlammobile in forum BB5
    Bài viết cuối: 29-12-2010, 11:51
  3. Cần pro giúp 3110c
    By THẢO-GSM in forum BB5
    Bài viết cuối: 27-12-2010, 16:00
  4. 3110c các bác giúp em với
    By tranthao in forum BB5
    Trả lời: 14
    Bài viết cuối: 03-10-2009, 21:33
  5. 3110c cần giúp đở
    By thanhvietmobile in forum J.A.F
    Trả lời: 17
    Bài viết cuối: 13-06-2009, 10:51
